93 YJ towing limits - JeepForum.com
 3Likes
post #1 of 22 Old 07-24-2019, 10:38 AM Thread Starter
VtwinVintage
93 YJ towing limits
Hi, I have a 2.5L 1993 YJ, a 2.5 suspension lift kit and 33" tires
I want to tow a trailer over 300 miles along the California coast, avoiding steep roads as much as possible
(As a reference I can do 85mph downhill, cruising at 70/75, no more than 50-55mph uphill with the setup I have, 40mph if it is very steep)
I figured it would not be wise to put more than 2000lbs despite I have a hitch rated for 3500lbs
The trailer empty weight is 900lbs, inside it there would be about 1100lbs of motorcycles parts
I still have a few more items I'd like to carry ( 500lbs maybe?)
If I put as much load as possible directly on the jeep and less on the trailer would that help a lot or is the whole idea just very stupid ?
On a regular basis I would never put as much stress on the little jeep but it's a one time trip and the road doesn't look that bad.
Any recommendations or tips on what to watch out for ?
Thanks
VtwinVintage is offline
post #2 of 22 Old 07-24-2019, 11:17 AM
jbolty
Administrator
jbolty's Avatar
Your main problem is not towing, but stopping. Any chance you can borrow or rent a bigger tow vehicle. I would at least try doing a test tow locally with about the same weight and see how it handles
jbolty is offline
post #3 of 22 Old 07-24-2019, 11:19 AM
Siva283
Siva283's Avatar
Its not about what your hitch can handle its more about brakes and suspension. YOur engine will get anything going it might be slowly but itll go there are 2 major problems first can your brakes handle it. I think you would be pushing your brakes to thier limits and possibly past second is your suspension. I believe YJ's stocl have a 2,000 capacity. SO no more than 200 pounds tongue weight. I think even at 200 it will have your rear end squatting pretty bad which takes weight off the front so sketchy steering. Then there is length of the trailer. Our jeeps are short wheelbase so you want a short trailer a trailer longer than the wheelbase will start steering this jeep so youll be fighting it.
In short I think that set up would be pretty much at the limits of a stock YJ with it being lifted that usually lessens towing.
Siva283 is offline
post #4 of 22 Old 07-24-2019, 02:04 PM
NHfireLJ
NHfireLJ's Avatar
As already mentioned... Its usually the stopping...
But 2 options.... More expensive option 1. Electric brakes on trailer and electric brake controller.... OR less expensive (kits about $450-500) option 2. hydraulic/surge brakes (usually found on boat trailers) no controller needed.
I'm installing surge brakes on my boat trailer so I can use the jeep and not the truck to tow it...
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #5 of 22 Old 07-24-2019, 03:48 PM
stephencbrinson
I have a 92, 2.5L, 5speed, 2.5in lift, stock rims and tires.
For what it is worth I regularly town an 5x10 utility trailer with all of my tools AMD materials. I frequently load 1500 pounds of lumber on the trailer. The jeep tows it fine but the more weight I add the scarier the stopping becomes.
I would appreciate trailer brakes.
Sent from my SM-G930U using Tapatalk
1992 YJ, 2.5L, AX5, D30, D35, 2.5 RE lift
Daniel 3:18
Ephesians 2:1-12
stephencbrinson is offline
post #6 of 22 Old 07-24-2019, 07:14 PM
NHfireLJ
NHfireLJ's Avatar
https://www.trailerpartsdepot.com/p-...-actuator.aspx
SOLD
style intake
NHfireLJ is offline
post #7 of 22 Old 07-24-2019, 07:41 PM
jbolty
Administrator
jbolty's Avatar
in CA a trailer weighing over 1500# is required to have brakes. Oddly, there is no requirement for brakes on a flat towed vehicle but there is a specification for how much distance you need to stop
"California law does not require brakes on towed motor vehicles provided the combination of vehicles meet the stopping requirements of Section 26454 of the Vehicle Code (VC). Section 26454 VC states in part, the service brakes of every motor vehicle or combination of vehicles shall be adequate to control the movement of and to stop and hold such vehicle or combination of vehicles under all conditions of loading on any grade on which it is operated. Provided your motorhome is assigned a gross vehicle weight rating of 10,000 pounds or more, your combination would be required to come to a complete stop within 50 feet from an initial speed of 20 miles per hour. Additionally, an emergency device is not required. "
jbolty is offline
post #8 of 22 Old 07-24-2019, 08:00 PM
NHfireLJ
NHfireLJ's Avatar
Wow thats pretty low wt rating... Figures its Cali. Not till you get 3000# do you need trailer brakes in NH. A lot of utility trailers sell at 2999# rating so they are cheaper and no brakes
SOLD
style intake
NHfireLJ is offline
post #9 of 22 Old 07-24-2019, 08:20 PM
Mechman71
All YJ's have a 2000lb tow rating as per the factory, regardless of engine, same as my mother's 2016 Cherokee Trailhawk, much to my surprise. I don't exceed 80% just in case I miscalculated.
'89 YJ "Night Eagle" 4.2 5spd, Spinnaker blue/grey, hard top and doors, mostly stock and RUST FREE!!
Mechman71 is offline
post #10 of 22 Old 07-24-2019, 09:03 PM Thread Starter
VtwinVintage
Well, when they provide the maximum rating they are already subtracting a fraction of the real number for safety reasons.
"I have a 92, 2.5L, 5speed, 2.5in lift, stock rims and tires.
For what it is worth I regularly town an 5x10 utility trailer with all of my tools AMD materials. I frequently load 1500 pounds of lumber on the trailer. The jeep tows it fine but the more weight I add the scarier the stopping becomes. "
Thanks, that's pretty much what I want to do, U-Haul trailers are 5"x8" and I'm almost sure they come with brakes
I know I'm playing a little bit with the devil but if I chose a path with little to no steep downhills, drive @45mph and let at least 2x the braking distance I should make it, right ?
I've never had that much load to carry
post #11 of 22 Old 07-24-2019, 09:19 PM
stephencbrinson
I don't have hills.bitnthere are several bridges. I slow down to 45ish uphill with the trailer. Give extra stopping distance, especially if the roads are wet
Daniel 3:18
Ephesians 2:1-12
post #12 of 22 Old 07-24-2019, 09:45 PM
jbolty
Administrator
jbolty's Avatar
Sound like you have already made up your mind and just want someone to agree with you to feel better about it. Good luck
Siva283 likes this.
jbolty is offline
post #13 of 22 Old 07-25-2019, 05:39 AM
Feetwet
Enjoying the Ride
Feetwet's Avatar
Until somebody cuts you off, or the ladder on the pickup truck 2 cars ahead flies off, or a deer shoots across the road, or...
Yeah, stopping is pretty important.
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is offline
post #14 of 22 Old 07-25-2019, 05:44 AM
stephencbrinson
Thanks....I've thought about adding brakes to my trailer. It is on the agenda.
Daniel 3:18
Ephesians 2:1-12
post #15 of 22 Old 07-25-2019, 05:46 AM
Siva283
Siva283's Avatar
Why did you come ask the question if you didnt want the advice. Also with a trailer that heavy with the 2.5 stock gears and 33's I dont think your gonna see 45mph without a 2 miles running start. For your sack I hope to emergency situation arises or you get cut off and if that does happen I hope the other guy survives because your gonna plow into him/her.
Siva283 is offline
