93 Yj Front Oil Leak - JeepForum.com
post #1 of 4 Old 01-24-2020, 10:05 AM Thread Starter
jeepinjc
jeepinjc's Avatar
Does anyone have any writeups or YouTube Vids of replacing all oil seals up front? I bought the kit but was hoping to do a little learning first.
Blue 93' YJ, 4.0, 5spd, skyjacker 4" lift, crager simulated beadlocks w/33" bfg muds, skyjacker swaybar disco's, dana 30/35 w/ 4:10's, skyjacker t-case drop, and many mods to do yet
Jeep Drivers who dig COUNTRY music member #13
jeepinjc is offline
post #2 of 4 Old 01-24-2020, 10:37 AM
jtec
jtec's Avatar
2014 JK Wrangler
Sorry for questions but
Whats your skill level - learning, DIYer, capable++ ?
do you have the manual?
Are you removing the engine?
All oil seals would make other component replacement practical as you have gained access to them, (timing set, CKP, oil pump) .
What is leaking?
I would have suspects before 'tearing' it up to reseal.
Before tearing into this tell us what why etc- big picture
jtec is offline
post #3 of 4 Old 01-24-2020, 11:07 AM Thread Starter
jeepinjc
jeepinjc's Avatar
I am pretty capable. I don't have a manual. I have replaced the motor once myself with a long block. I am not planning on removing the engine, I don't feel it is needed. The jeep runs fine but is leaking oil up front and therefore loses oil pressure. The motor isn't terribly old so I am not overly concerned about replacing the timing set (I know I will be right there, just unneeded expense)
I have done all the work on this myself. SOA on Waggy Springs to stretch it 4", on 37" KM2 tires, AW4 trans set to shift gears manually without clutch, and the list goes on.
jeepinjc is offline
post #4 of 4 Old 01-24-2020, 11:15 AM
jtec
jtec's Avatar
2014 JK Wrangler
thats a clue front of eng is leak area AND Losing oil pressure - I want to think on that,
jtec is offline
