92 YJ Trouble Code 41 - JeepForum.com
post #1 of 4 Old 05-21-2019, 09:02 PM Thread Starter
YjTimmy15
YjTimmy15's Avatar
I’m going to need some help identifying the problem for this code. Today my check engine light came on while driving. It threw me a whole bunch of codes at first. One about the oxygen sensor, alternator, a/c and the one for disconnected battery.
Eventually just code 41 for the alternator was present.
My Jeep would not start. I assumed it was a bad battery. Jumped it and it started up. I let it run for a while and shut it off and turned it back on and it wouldn’t crank. Dash lights were dim and the voltmeter was in the red just above the 9 mark.
I tested the battery with a multi meter and it read about 12 with the Jeep off. Jumped it again and tested the battery and it read 14. Turned the Jeep off and turned the headlights on. The headlights didn’t come on at first, and about 10 seconds later they popped on. Like the voltmeter gained voltage.
I took the battery to get tested at autozone for the hell of it. It showed the battery was good and charged at 94%.
Being that I replaced the alternator a year ago, I don’t think it could be that. My wiring appears to be good and I checked the fuses and relays.
What test or procedures should I do next to fix this issue ?
YjTimmy15 is offline
post #2 of 4 Old 05-22-2019, 07:13 AM
Magnum
Electrical gremlins can be hard to chase down. The first things I always check are the wires and connections. Our YJ's are at least 25 years old now, so the copper breaks down in the wire, rust can cause ground connections to become insulated, etc.
The symptom of throwing a lot of codes as it dies is characteristic of an alternator or voltage regulator going out. I am not sure whether the 92 had the regulator in the alternator or in the ECM.
Last comment: just because the alternator is relatively new does not mean it cannot be bad. My daughter's starter died on a road trip about a year ago, so it was replaced at a national chain garage. I replaced it about 2 months ago because that new starter went bad.
Good luck.
94 YJ, 4.0, 5-Spd, 33x12.5 GY Duratrac, RE 2.5" Lift
Brown Dog Mounts, 8.8 w/ disks, TrueTrac f & r
Magnum is offline
post #3 of 4 Old 05-22-2019, 10:20 AM
HAZCAT
HAZCAT's Avatar
I would go get the alternator tested at this point too. Then if it is good you can rule out the battery and alternator and start looking at the wiring for issues. A bad ground wire or connection may be the issue but I would take the alternator and test it before you spend a bunch of time and effort on other stuff or spend money you don't need to spend. When you take the alternator out, check the connectors for it as well and make sure they still look good.
'84 CJ7, 44, 14 bolt, twin stick 300, 109"whl base, 4 linked
'93 XJ Cherokee
'70 CJ6 Dauntless v6
HAZCAT is offline
post #4 of 4 Old 05-22-2019, 10:27 AM Thread Starter
YjTimmy15
YjTimmy15's Avatar
Update: Finished testing everything thoroughly with my multi meter. You were right regarding the wiring. There was a small bit of corrosion internally on the positive battery wire. Replaced it and everything works normal now. Thank you for the tip.
HELP...2001 TJ 4.0. Limp Mode, P0305 Code Herkybird70 TJ Wrangler Technical Forum 8 10-28-2018 06:15 PM
Crank Shaft Position sensor P0335 error code trouble artffjr Engines & Drivetrain 3 07-23-2018 05:43 PM
Occupant Restraint Controller Trouble Code C3800 ? acabtp WK Grand Cherokee & XK Commander Forum 3 06-03-2018 12:12 PM
Engine Code P2245 RetLCD WK2 Grand Cherokee Forum 31 02-21-2018 03:17 PM
P0101 Code 2007 CRD-Please Help, tnx Donuts31 WK Grand Cherokee & XK Commander Forum 3 12-15-2017 12:17 PM
