'89 YJ Motor Mount Bracket Bolts - JeepForum.com
 1Likes
  • 1 Post By bpounds
post #1 of 10 Old 07-20-2021, 06:00 PM Thread Starter
jimsahm
Question: I re-installed and torqued to FSM value the engine bracket bolts (ones that hold brackets to the block). I read elsewhere to get new hardware and to not reuse the bolts. Any opinion if I should replace bolts or roll with it? Just re-installed engine (rebuilt 4.2L) and reused the old mount bolts.
Thoughts?
Thanks,
Jim
jimsahm is offline
post #2 of 10 Old 07-20-2021, 07:16 PM
timatoe
timatoe's Avatar
I re-used mine 15 years ago, they're still there.
timatoe is offline
post #3 of 10 Old 07-21-2021, 09:24 AM
bpounds
bpounds's Avatar
I think it is the 2.5 that has repeated issues with the motor mount brackets. Not really an issue on the 4.2, and as long as the original bolts are in good shape I say reuse them.
Bill
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2" lift + 1" BL + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #4 of 10 Old 07-21-2021, 02:45 PM
Waternut
Waternut's Avatar
I think you'll have more issues trying to find quality metric bolts of equivalent strength than you will reusing the old ones.
Waternut is offline
post #5 of 10 Old 07-21-2021, 08:09 PM
Boojo35
1987 YJ Wrangler
Torque to yield bolts and bolts that need to be replaced during a procedure has become dirty business IMO. Sure, some need to be replaced for sure. But, if a manufacturer puts a replacement footnote in some obscure place and that particular bolt replacement is not documented on a repair order it shifts or potentially shifts liability in stupid effing ways. This industry has become retarded.
If they are clean bolts, good threads, screw in an out with fingers, not rusty, and do not look distorted or thin in places. Reuse them.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #6 of 10 Old 07-22-2021, 09:41 AM
bpounds
bpounds's Avatar
Pretty sure the 4.2 has all SAE bolts. The motor brackets were either 5/16 or 3/8 NC.
timatoe likes this.
Bill
bpounds is offline
post #7 of 10 Old 07-22-2021, 10:08 AM
jbolty
Administrator
jbolty's Avatar
right, don't think there was anything metric until the 4.0
jbolty is offline
post #8 of 10 Old 07-22-2021, 10:49 AM
timatoe
timatoe's Avatar
Could be mishmashed parts, but "most" everything on mine is SAE but some oddball stuff like power steering pump bolts are 15mm.
timatoe is offline
post #9 of 10 Old 07-22-2021, 02:11 PM
Waternut
Waternut's Avatar
Makes sense. I was just basing that off the 2.5L engines I worked with and I think those were 12mm because mine were messed up and 1/2" bolts wouldn't fit.
Waternut is offline
post #10 of 10 Old 07-25-2021, 06:20 AM
fishadventure
fishadventure's Avatar
Yes.
As far as replacing non-motor bolts: I’m confident that other than spring ubolts, ujoint straps and bolts, and (dubiously) ujoint flange bolts there are no torque-to-yield bolts on a YJ outside the motor/driveline internals.
Secondly, unless your use ARP or other high-grade US or German brand the oem AMC and Chrico bolts are WAY better quality alloys and have the right ‘flange’ on cap bolts and nuts as compared to the hardware store or tractor supply. It’s not just what you see, it’s in the alloy and heat treat- what you can’t see. The oem AMC nuts and bolts in particular are very good alloy.
If you cleaned them and if paranoid used blue threadlocker they’ll be fine.
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
