89 YJ 2.5 and mystery connector - JeepForum.com
post #1 of 8 Old 08-07-2020, 08:29 AM Thread Starter
kevindee866
Hi all. New to Wrangler life. I recently bought an 89 with a lot of work done to it but a few things need to be done. Im chasing a fast idle 2000 rpm. Tracing vacuum setup and lots of dangling hoses. I think I have a plan bit for the life or me I cannot figure out what goes in here. Anyone have a pic of their 89 engine compartment. This is diagonally left behind throttle body.
Sent from my iPhone using Tapatalk
kevindee866 is offline
post #2 of 8 Old 08-07-2020, 08:59 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Pic is fuzzy. What type of connector is it? Vacuum, or electrical?
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 8 Old 08-07-2020, 09:06 AM
fishadventure
fishadventure's Avatar
Ya, resolution is so low I don’t know what I’m seeing or not seeing.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #4 of 8 Old 08-07-2020, 10:41 AM Thread Starter
kevindee866
Hopefully this is better. Looks like a sensor?
post #5 of 8 Old 08-07-2020, 12:36 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Isn't that the EGR valve vacuum pipe?
Is this YJ been Nuttered? Lots of stuff gets disco'ed if it has been Nuttered.
post #6 of 8 Old 08-08-2020, 12:21 AM Thread Starter
kevindee866
Thanks for responses. Turns out that connector is to the CCV valve on rear of valve cover. Previous owner just ran direct to air cleaner from ccv
post #7 of 8 Old 08-08-2020, 05:38 AM
fishadventure
Did that fix the rpm?
BTW the idea of the vacuum to rocker cover is this: one end pulls air from the air cleaner while the other end has manifold vacuum with a limiting valve. That way A) air going into crankcase is ‘filtered clean’ B) blow-by or oil vapors are burned by the engine C) oil-soaked motor doesn’t exist quite so much anymore
The most important thing is under vacuum, feed it filtered air!
post #8 of 8 Old 08-08-2020, 07:24 AM Thread Starter
kevindee866
Still working thru it all. That CCV was already connected so that mystery solved. Found that there is a vacuum line with a connector from air filter that plugs in and then goes to throttle body. That was just hanging. So today is to continue trace. I till need to trace egr canister solenoid ad one line is disconnected and also have to find out why the canister port that should have the line to the gas tank is not connected (def new tank and fuel likes were done before I got it)
