89 yj 2.5 5 speed - JeepForum.com
post #1 of 25 Old 08-17-2021, 09:40 AM Thread Starter
SPCKENDRICK
SPCKENDRICK's Avatar
89 yj 2.5 5 speed
Alrighty so my yj likes to run around 1200-1500 RPM I checked as many vacuum lines I could fine and tested the idle speed motor. I got it down to like 1000 but it wont drop below that and dumb *** California says it needs to be between 800-950 for them to smog test it.
Any Ideas
SPCKENDRICK is offline
post #2 of 25 Old 08-17-2021, 02:13 PM
cas6969
cas6969's Avatar
Okay... this may come off wrong, but... have you tried to adjust your idle speed motor?
I replaced mine but didn't have the means to adjust it/set it up the "correct way", so I didn't. I also didn't have the correct adjustment screw for it, I just found a screw that fit. I also never put a lock nut of any type on it. So every now and then I have to adjust my idle. I just turn the screw one way or the other to bring it up or down.
So I guess my suggestion is, turn the screw in a little and slow it down.
Silicone, the thinking man's duct tape.
cas6969 is offline
post #3 of 25 Old 08-17-2021, 07:46 PM Thread Starter
SPCKENDRICK
Yes I did, now I will say I dont know the proper procedure for setting the idle speed motor. I briefly read something about a plug that extends the rod, but for the most part Im not sure. Im also not sure if the TPS sensor could have that much of a major roll on the idle I mean its just a bar that moves when the throttle blade opens I could also be wrong lol
post #4 of 25 Old 08-17-2021, 08:28 PM
93YJ4FUN
Years ago I had a car with a bad TPS. It had a bad spot where it would think I let off the gas. Push past that and it would rev the engine to catch up to that pedal position.
That same TPS was dirty and caused some other issues. Cleaning it helped a bit, but ultimately replacing it fixed the problems.
As the bar moves, it changes the info being sent to the ECU. The other peeps here can explain exactly how it works.
93YJ4FUN is offline
post #5 of 25 Old 08-18-2021, 05:26 AM
fishadventure
fishadventure's Avatar
Intake/exhaust manifold gasket leaking? Air leak tells the fi to add gas, gas and air =higher idle.
Does it idle high cold, too, or just up to temp?
The tbi jeeps are difficult with manifold/exhaust leaks. The unlit propane torch test is in order here.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #6 of 25 Old 08-18-2021, 09:16 AM Thread Starter
SPCKENDRICK
Im probably gonna buy a new tps just to eliminate it and its cheap anyways, as for the in lit propane test Im pretty sure I have an idea of what your talking about but please shed a little extra light on the process.
post #7 of 25 Old 08-18-2021, 10:04 AM
EABiker
You can check for vacuum leaks by spraying something flammable, (like propane, or even better, carb cleaner), around all the hoses and manifolds of a running engine, and listen for an RPM change. The RPM change would indicate a vacuum leak.
EABiker is offline
post #8 of 25 Old 08-19-2021, 05:17 AM
fishadventure
Unlit thin torch head moved around the manifold gasket, tbi base, hoses, even exhaust joints, front axle disconnect harness etc. you can poke it in all the cramped places and it will have an effect in rpm if there’s an air leak.
post #9 of 25 Old 08-19-2021, 05:21 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
just to clarify...
Fish doesn't mean with the torch head ignited. Just releasing the gases within the tank it's attached to. Maybe this wasn't necessary, but ya just never know in the /f12
Man, California
~YJOTM MAY '16, JULY '19~
bruinjeeper is online now
post #10 of 25 Old 08-19-2021, 06:57 PM
cas6969
cas6969's Avatar
I'd be worried about finding exhaust manifold leaks instead.
cas6969 is offline
post #11 of 25 Old 08-19-2021, 07:21 PM
fishadventure
Propane’s sorta safe because it doesn’t / can’t ignite less than or over than ~5% propane:air concentration
post #12 of 25 Old 08-27-2021, 09:40 PM Thread Starter
SPCKENDRICK
Ok so I did the propane torch test and yes I was aware he meant unlit lol. Didn’t really find anything but I replaced the intake/exhaust manifold gasket and I replaced the EGR. I also cleaned the throttle body out extremely well and pulled the idle speed motor apart to make sure nothing was broken. And I still have the same issue except now it idles at like 1000. Smog guy says it needs to be below that!
post #13 of 25 Old 08-28-2021, 02:52 PM
fishadventure
Mighta been Luuca and maybe jeeperdon? have posted destructions in the past on adjusting the idle stepper
Anybody got a link?
post #14 of 25 Old 08-30-2021, 10:17 PM
SevenSlotAddict
Cool tip on the propane. I have a torch on my truck and will use this method to check for exhaust gasket leaks. My '90 2.5L YJ also idles at 1000. I guess my question is are the emission guys giving you the rpm reading or is it your gauge? YJ gauges are known for inaccuracy. Just a thought. 100-150rpm isnt much of a difference.
Good luck!
SevenSlotAddict is offline
post #15 of 25 Old 08-31-2021, 05:18 AM
Siva283
Siva283's Avatar
Good luck!
Propane works in the intake and vacuum side because it makes it to combustion. Its not really gonna do anything on the exhaust side except blow it out the exhaust
Siva283 is offline
