88 YJ seat help - JeepForum.com
post #1 of 3 Old 04-20-2019, 06:46 AM Thread Starter
Broselrc31
88 YJ seat help
The seats and seat risers in my 88 have been replaced. The seat sits too high, close to the steering wheel. The slide is all the way back. I have been looking for seat brackets that would lower the seat but so far all I can find looks like what's in there. Any advice?
Broselrc31 is offline
post #2 of 3 Old 04-23-2019, 09:08 AM
Que89YJ
Use this link and follow the directions to search the forum using the Google method in the thread. There is a lot of different threads on dealing with the seat brackets.
https://www.jeepforum.com/forum/f12/...oogle-1003734/
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #3 of 3 Old 04-23-2019, 02:30 PM
KfoySTL
Que89YJ--thanks for the tip on searching.
OP--I replaced the riser and slider in my 95 and it is definitely higher than I want. I looked around (mostly for a flip up version--mine was fixed) and bought two different brands--one claimed to be lower and wasn't. I looked all over the place for a non-rusty OEM riser and heard that they are as hard to come by as the D35 with 4:10s. Unfortunately, I don't think you will find anything without a decent amount of fabrication.
I have a tilt wheel and have decided to deal with it in the short term.
The flip up version I have is torqued a little bit and doesn't move as freely as it should because my floor is rusty and rebuilt. I kept the OEM fixed riser and will eventually go back to it after I figure out how to attach my slider to it.
No useful info other than either a compromise or fabrication/tricky sourcing is likely in your future. If you find a better solution, please let me know!
KfoySTL is offline
JK Rear Seat (2 DR) in my LJ yellow_dolphin TJ Wrangler Technical Forum 10 11-20-2018 10:04 AM
OE seats leave a lot to be desired, I just replaced mine with Suspension Seats Jerry Bransford TJ Wrangler Technical Forum 50 09-24-2018 01:47 PM
YJ Rear Seat Relocation for tall passengers natewill18 YJ Wrangler Technical Forum 3 03-13-2018 10:17 AM
Ranger Bench Front Seat Swap Writeup Awesome YJ Wrangler Technical Forum 6 03-11-2018 02:27 PM
How to- WJ Driver Side Outer Seat Bolster Reinforcement srmitchell WJ Grand Cherokee Forum 3 02-23-2018 08:35 PM
