87 YJ gauge cluster wiring diagram - JeepForum.com
post #1 of 7 Old 03-31-2018, 12:07 PM Thread Starter
acdc0525
I have an 87 YJ that I am trying to change out the gauges with digital ones, but I am needing a wiring diagram. Does anyone have one they can download. I also need the diagram for the speedometer and tachometer.
acdc0525 is offline
post #2 of 7 Old 03-31-2018, 12:23 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
I do have a PDF called: Jeep YJ FSM Wiring diagrams. It must have been put together by someone, and I don't know where I got it. But it does have the '87 dash schematics. Just not the speedometer, I think because it was mechanical in '87. It has info all the way up to '94. So maybe you can use a newer model speedo schematic. PM me if you would like it.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #3 of 7 Old 03-31-2018, 12:56 PM
jtec
jtec's Avatar
2014 JK Wrangler
I believe it was a mechanical speedo.
hoping Mr.B could give this quick check
I do not have a way to double check my diagram -
jtec is offline
post #4 of 7 Old 03-31-2018, 12:58 PM
timatoe
timatoe's Avatar
This is what mine were on my '90. Disregard the pin #'s as though are where I put them in a 12 pin Molex connector and the gauge color is what I ran in my home built harness. The speedo only has a cable and lights, the tach should be very clear once you pull the gauge.
timatoe is offline
post #5 of 7 Old 03-31-2018, 01:33 PM Thread Starter
acdc0525
Thank you very much for the responses.
acdc0525 is offline
post #6 of 7 Old 03-31-2018, 01:37 PM
Mr.B
Mr.B's Avatar
I can't even read that. I can barely read the one I have. But here it is.
Ham license:
Everyone is Welcome
Mr.B is offline
post #7 of 7 Old 03-31-2018, 01:48 PM
Mr.B
Mr.B's Avatar
If you're having trouble reading that, PM me for the link. It's easier to read in PDF form.
Ham license:
Everyone is Welcome
Mr.B is offline
