87 Wrangler YJ 4.2L Starter grinding - JeepForum.com
 1Likes
  • 1 Post By fishadventure
post #1 of 8 Old 03-03-2019, 09:10 AM Thread Starter
cutlasscharlie
We bought our 1987 YJ 4.2L used. It had a working starter on it and then a few months later it burned out. We bought a new starter at O'Reillys Auto in Southern California. The starter made a grinding sound like the gear was running against thin tin. We took the starter back and tried another. Same thing. Went through three starters. Finally, took it to a shop that specializes in Jeeps and the mechanic said we pretty much ruined the flywheel teeth.
Took the Jeep home and replaced the flywheel ourselves ( that was one big job!!). Put a starter on it. Same thing. Took it back to the shop and he tried several starters from different companies including NAPA. Same problem. He recommended we buy a starter from Quadratec which we did. The starter they sent us was much smaller AND it had two posts for hooking up wires where our starter only had one post for the cable off the positive terminal of the starter solenoid which is mounted on the firewall. Also, the new starter already has a starter solenoid.
We researched the connections and it was recommended on ta forum to jump the two posts and connect it with the one cable. The starter works, but the drive gear does not reach the flywheel. We are at the end of our rope. Where do we get a starter that will actually work? Anyone who can give us some info, PLEASE help!! Pictured below are the two starters side by side and the single pole hook up on the "original" starter.
cutlasscharlie is offline
post #2 of 8 Old 03-03-2019, 10:15 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
I would buy a genuine factory original Jeep starter. Either buy a brand new Jeep starter or buy a used genuine Jeep part from the junkyard and a have a local shop rebuild it. The local shop should use US, German or Japanese parts. Most auto parts stores sell cheap crappy Chinese made and/or refurbished parts, some that even come with a "Lifetime Warranty". These parts are poorly manufactured and/or made with inferior materials. They are often out of specification, or even failed, right out of the box. The ones that are not faulty many times will have a short service life before they fail. Always buy top quality replacement parts and genuine Jeep engine sensors. Numerous threads detail long and frustrating searches for a "problem" that ended up being cured simply with genuine Jeep repair parts.
Cheap parts are cheap for a reason.
You also need to find an auto parts store that has counter people that can find their arse with both hands at once. You either received the incorrect part, or somebody managed to put the wrong part in the right box.
CJ7-Tim is offline
post #3 of 8 Old 03-04-2019, 10:57 AM
CESWAMPY
1987 YJ Wrangler
It looks to me the starter you got from quadratec is item #55111.7 which is for a 88-90. I think you need item #55111.00 which is for a 72-87
CESWAMPY is online now
post #4 of 8 Old 03-04-2019, 11:10 AM
vadslram
Are you 100% sure of the block you have?
All those starters and none of them worked, to me means that one of the other components is an aftermarket switch. Since you replaced the flywheel that leaves the crank or the block. One of the two is positioning the flywheel out of the starter's reach.
If you can find a 4.0 starter you could try that, but I don't know if there is much difference.
The problem with vehicles as old and well worked as our YJs is that you never know what "modifications" have been made before you got it.
vadslram is offline
post #5 of 8 Old 03-04-2019, 11:23 AM
fishadventure
fishadventure's Avatar
Someone correct me...
My ‘89 2.5 had a bolt-up starter that used shims to set the starter to flywheel, Chevy style.
What you are showing is a later model starter if I’m not mistaken. Post Chrysler 91-95+
So your starter needs to fit, not be the ‘correct’ part number
Someone more knowledgeable please correct me. I’m not a guru
Boojo35 likes this.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #6 of 8 Old 03-04-2019, 05:57 PM
Boojo35
^^^^ I have run into some weird scenarios a few times in my career where people swapped things out be it a different year block, flywheel, blah blah blah. It really sounds like a situation where you have a Frankenbuild.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #7 of 8 Old 03-04-2019, 06:59 PM
bpounds
bpounds's Avatar
'87 used an oddball flywheel and starter. If you study part numbers on rockauto, you will see. If you had used an '88 or later flywheel when you changed it, you could used the '88 and later starter. There is a lot of screwups out there on this, due to so many drivetrain swaps going on. But this has been documented on JF many times.
BTW, 2.5 is totally different.
Bill
Jeepers drive high!
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #8 of 8 Old 03-07-2019, 12:45 PM
Quadratec
Vendor
Quadratec's Avatar
Hi there,
Sorry to see this. If you can PM me your order number we can take a look into this.
Thank you & have a great day!
-Justin
We Price Match,
us for a quote
Active Hours: 9am-5pm EST Monday - Friday
Quadratec is offline
5 Jeep Wrangler JK Factory Wheels Like New: $500 kcall333 Tires & Wheels 0 08-23-2018 05:04 PM
Starter grinding Jake223 XJ Cherokee Technical Forum 1 08-17-2018 01:39 PM
Starter grinding on flywheel Haggenator Jeep CJ Forum 5 06-25-2018 08:21 PM
Cold Morning Starter Grinding JeepHog1 JK Wrangler Technical Forum 0 04-20-2018 08:17 PM
Starter grinding noise less after some use. Why? kjatie16 Grand Cherokee General Discussion 0 03-12-2018 05:59 PM
