8.8 rear seal replacement - JeepForum.com
post #1 of 7 Old 07-09-2020, 11:19 AM Thread Starter
el guapo
el guapo's Avatar
Need to replace the rear axle shaft seal in my YJ's 8.8. For those who've done this already, anything I need to look for? Only one side is leaking, but if I have to drain the diff and pull C-clips, I might as well do both...
I'm a fan of using OEM parts, so was going to pick up 2 Motorcraft seals. Looks like they are made in China. Should I still go with Motorcraft, or should I get Timken seals? Any advice appreciated...
i know, i know... pull over.
el guapo is offline
post #2 of 7 Old 07-09-2020, 12:12 PM
jbolty
jbolty's Avatar
might as well replace the bearings while you are in that far, I think they were only about $20 plus change the pads on the parking brake. 1000x easier with the axles out.
otherwise, easy job
jbolty is offline
post #3 of 7 Old 07-09-2020, 05:42 PM
Boojo35
1987 YJ Wrangler
otherwise, easy job
I totally agree. Especially on the parking brake shoes. The 8.8 has some of the most difficult parking brake shoes to replace that are known to man.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is online now
post #4 of 7 Old 07-09-2020, 07:20 PM Thread Starter
el guapo
el guapo's Avatar
Thanks fellas. Got it blown apart tonight and the seal is definately leaking. Amateur mechanic here never done a bearing replacement but it looks straight forward and parts are cheap so will do that.
Whats so bad about the parking brake shoes? I mean, I hate drum brakes as much as the next guy with all the springs but they don't look horrible...
I learned a lesson about using OEM parts with my LS swap so will probably just get all Mastercraft parts even though they are made in China <grrr>
el guapo is offline
post #5 of 7 Old 07-09-2020, 08:02 PM
jbolty
jbolty's Avatar
those shoes are easy, if the axle flange is not in the way
jbolty is offline
post #6 of 7 Old 07-09-2020, 11:01 PM
Drix
Drix's Avatar
I used Moog, I dont think you can go wrong with timken either. Make sure your axles are smooth and clean where it will rest around the seals otherwise you will be back in there doing it again.
95' YJ 4" lift 33"x12.5r15's D30/8.8 locked with 4:88's
USMC Jeep Club #6
"Why in hell can't the Army do it if the Marines can. They are the same kind of men; why can't they be like Marines."
Gen. John J. "Black Jack" Pershing, USA; 12 February 1918
Drix is offline
post #7 of 7 Old 07-10-2020, 10:01 AM
jbolty
jbolty's Avatar
axles seals run in a lot of dirt so it's not uncommon for the shaft to develop a tiny groove where the seal runs. Sometimes it's possible to put the seal not quite all the way seated to run in a different place but with axle end play that does not usually work very well or for long. When I swapped mine I went to the JY and pulled different shafts from a newer and cleaner explorer. I needed some spares anyway.
jbolty is offline
