5.3 swap tcase low switch - JeepForum.com
post #1 of 5 Old 06-26-2020, 05:05 PM Thread Starter
FergiesJeep
so a couple of years age i did a 5.3 swap 4l65E and a NP241C i have a single wire to my ecm that tells it it is in low gear so it can adjust shifting pattern to match low gear it the T case there is a plug that has 3 wires the connector has 3 wires i was wondering if anyone has a the wiring diagram and how the ran this. Would be nice to use low gear...
FergiesJeep is offline
post #2 of 5 Old 06-26-2020, 07:46 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
A 3-wire connector on the back of the t-case is the VSS, not the hi/lo switch. The hi/lo switch on a '93 YJ's t-case is vacuum. The only electrical line involved is on the front axle. When the vacuum system activates the axle coupler for 4wd, it also grounds that wire, which goes to the dash 4wd indicator. The indicator gets constant +12v from the ignition system.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 5 Old 06-28-2020, 08:01 AM Thread Starter
FergiesJeep
Correct but i dont have the NP231 i have a NP241C out of a 93 chevy that has a 3 wire plug.
post #4 of 5 Old 07-02-2020, 08:44 AM
NHfireLJ
NHfireLJ's Avatar
Try google...
found this, half way down the page
https://www.gmt400.com/threads/np241...arebody.27105/
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #5 of 5 Old 07-02-2020, 02:06 PM
jmart2119
Send It!
jmart2119's Avatar
Not sure about the 5.3 computer but in my 5.7 the 4L60E/NP241, one of the pins in the computer just needed a ground when in 4Low. I hooked it up to a toggle switch on my dash and engage the ground when Iím in 4Low.
From my build thread:
2018 YJ of the Year
YJOTM | Aug'15 | Dec'16 | Jan'18
1989 YJ - 98 5.7L Vortec, 4L60E, NP241, D30+8.8, 5.13's, 35" ProComp MT2's
jmart2119 is offline
