5.2L/AX15 Swap Bellhousing - JeepForum.com
post #1 of 7 Old 11-22-2011, 03:25 PM Thread Starter
Delta347
Delta347's Avatar
So I'm planning to do a 5.2L swap from my ZJ to my YJ. Im also doing a swap from the TF999 to an AX15.
I've been trying to find a a dodge bellhousing from the mid 90s from a v6 but haven't had any luck. I keep finding the 87-93 one.
Any ideas where to look online? Or what exact years and engine combos are capable of being donors?
My iPhone will poison your Android.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #2 of 7 Old 11-24-2011, 08:55 PM
444
They can be easy to find sometimes and hard to find other times. I eventually found one on ebay.
444 is offline
post #3 of 7 Old 11-28-2011, 09:41 AM
bmgadg
bmgadg's Avatar
Found plenty on car-part.com and had one shipped to me for around $60.
bmgadg is offline
post #4 of 7 Old 08-10-2012, 08:14 PM
95cherokee318
hey guys, i'm in the process of swapping my auto to the ax15 in my zj, will my bell housing bolt onto the ax15? what can i do?
any suggestions???
95cherokee318 is offline
post #5 of 7 Old 08-11-2012, 02:32 AM Thread Starter
Delta347
Delta347's Avatar
any suggestions???
You'll need what I was thinking of looking for, the late mid 90s Dodge V6 bellhousing for an AX15.
The V6 has the same pattern as the magnum v8 but the V6 had the AX15 (Aka NV4550) where as the magnum v8 had auto in chevy trucks. So just look for the Dodge/Chrysler V6 from trucks in the mid-late 90s...I forget what model it was specifically since I went with a 4.0 for now since I am unsure what I will be doing with my ZJ at this point.
check car-parts for the bellhousing once you search the forum/google more for the model of truck, the info is out there, good luck!
Last edited by Delta347; 08-20-2012 at 11:49 PM. Reason: "bmgadg"'s post made me realize I typed chevy instead of Chrysler.
Delta347 is offline
post #6 of 7 Old 08-11-2012, 02:39 AM
95cherokee318
thanks! would it work from a dakota?
and when i look for the other bell housing, do i search under ax15? from dodge/chevy v6?
post #7 of 7 Old 08-20-2012, 03:05 PM
bmgadg
bmgadg's Avatar
Dakota came with the ax-15 and the bellhousing to mount to magnum engines. Swap the bellhousing to your ax-15 and bolt it to any dodge magnum. I seriously doubt anything from a chevy is going to work.
bmgadg is offline
