5.2 swap electrical question, Orange wire - JeepForum.com
post #1 of 6 Old 07-05-2020, 07:44 PM Thread Starter
V8FUN
I know I've read about this somewhere, but I can't find it anywhere. One last wire (for now anyway) I'm not sure what to do with regarding the swap. Position #16 of the "Headlamp and Dash" connector (ENG2) on the firewall is an Orange wire that is K7 circuit. 93 Jeep fsm says it goes to pin #7 on the pcm (among others), and lists it as VSS Mag (+). 93 Dakota (donor) fsm says pcm pin #7 is 8 Volt Input, is also an Orange wire, and is also K7 circuit. Should I assume K7 is K7 and jump the orange wire to pin #7, or is that too easy?
V8FUN is offline
post #2 of 6 Old 07-06-2020, 06:23 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
What are you trying to get working, without the wire color circuit number details?
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #3 of 6 Old 07-06-2020, 07:36 AM Thread Starter
V8FUN
Not trying to get anything working per se, just making sure I get all the required connections made.
V8FUN is offline
post #4 of 6 Old 07-06-2020, 09:34 AM
JeeperDon
JeeperDon's Avatar
Sorry, I'm not the best person to help you then. When I did my swap I went function by function, not wire by wire.
Web Admin for
post #5 of 6 Old 07-06-2020, 09:38 AM Thread Starter
V8FUN
Ok, it IS a simple matter of K7 goes to K7. I was able to talk to someone who would know, and the circuit numbers match so it doesn't matter what the description says. I was able to find the right schematic in the donor fsm and found that the VSS is part of that circuit too, same as the Jeep fsm. I missed that the first dozen times thru the schematics
V8FUN is offline
post #6 of 6 Old 07-06-2020, 09:45 AM Thread Starter
V8FUN
Yeah, the gm swap is harder than mine. MOST of the wires are the same color and go to the same places.
V8FUN is offline
