4wd indicator light switch - JeepForum.com
 3Likes
post #1 of 41 Old 01-12-2010, 02:14 PM Thread Starter
Johnyakimo1855
I have a early model YJ (87-91) and I have a loose vacuum line (yellow) that is supposed to connect to the 4x4 indicator light switch. I was told it is nex to the battery. The only thing next to the battery on the jeep is the starter solenoid. Does anyone have a picture of the swich so I can see what it looks like and I can see if it is rattling around somewhere. The PO was had no business working on this jeep it is a mess. Thanks
Johnyakimo1855 is offline
post #2 of 41 Old 01-13-2010, 08:51 AM
Mugzz819
I don't have enough posts on here to upload a pic but if you still need one send me a pm with an email address and I can get a pic for you today or tomorrow. I have a 90 so it should be the same. Also, make sure the red one isn't disconnected, I had issues with that one and that messed up the system. One nice thing about the whole vacuum system thing is when you figure it out and the fix only takes a few minutes and few bucks lol.
Mugzz819 is offline
post #3 of 41 Old 01-13-2010, 09:13 AM
RebuildRookie
RebuildRookie's Avatar
The indicator is above the starter relay solenoid. It is light blue in color and has a vacuum line and a black w/yellow tracer wire going from it to the engine harness. It is on an L shaped bracket that attaches to the firewall. You can see the top of it in the bottom left corner of this pic
I'm a more proactive person.
You spray the ants before they get in your house.
You plant the crops before you starve.
And you keep the terrorists in check before you get your *** blowed off.
RebuildRookie is offline
post #4 of 41 Old 12-07-2010, 07:23 AM
jeffsme
sorry fellas mine aint like that . my coil is on the left side of the block in a bracket near the dizzy cap !
jeffsme is offline
post #5 of 41 Old 12-07-2010, 10:25 AM
superj
superj's Avatar
mine too. pm me so i can remember to get a pic for you later
the xj is the only jeep left in the driveway
superj is offline
post #6 of 41 Old 12-07-2010, 10:33 AM
Que89YJ
Que89YJ is offline
post #7 of 41 Old 01-31-2020, 03:57 PM
manosr
Ancient thread, I know. But I need help testing the switch - and if you guys know where I can find it as a spare part. I don't even know how its officially called. Thanks in advance...
manosr is offline
post #8 of 41 Old 01-31-2020, 04:53 PM
jbolty
Administrator
jbolty's Avatar
Get a switch for a TJ. It will screw right into the transfer case and does not depend on vacuum hoses.
jbolty is offline
post #9 of 41 Old 01-31-2020, 05:28 PM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
God damn. I actually don't mind necrothreads.... aside from the constant torture of countless blurry photobucket posts.
Is your 4WD still vacuum actuated? As in, two piece passenger side?
If so, just get a new YJ 4wd switch. The TJ switch should be used in conjunction with the solid one piece axle mod. Simply putting in the TJ switch will send the signal to the light - but wont actuate your 4wd as i remember it as our stock configurationg requires vacuum to actuate a collar connecting the two piece shaft. U might as well get a whole new vacuum harness for it... dirt cheap and good insurance... while you're down there.
I have a TJ switch at the Tcase, it sends the electrical signal that tells me i am in 4wd. But my one shaft doesn't need vacuum to connect my 4wd, as my passenger wheel is always engaged with the gears in the differential.
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #10 of 41 Old 02-01-2020, 12:59 AM
manosr
Its a stock YJ with the amazing vac system. I just replaced the harness, axle seems to lock but I get no dash indication
manosr is offline
post #11 of 41 Old 02-01-2020, 07:13 AM
bruinjeeper
What do u mean seems to?
U should clearly feel the difference.
Have you checked if the bulb is burnt out?
post #12 of 41 Old 02-01-2020, 08:23 AM
fishadventure
fishadventure's Avatar
Early years had the switch on the firewall, not the CAD actuator. Merely a vacuum switch and extry vac lines.
Later years the switch is on the CAD actuator and a plunger switch senses when the fork moves into 4WD position.
(Take a pic of CAD actuator and post it. )
[size=“3”]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #13 of 41 Old 02-01-2020, 02:20 PM
manosr
I was trying to be funny (not successfully). I just haven't gone off-road since I changed the harness to make sure everything works as it should. But it locks the axle.
My switch is on the firewall, the blue one. I connected the vacuum, not sure if the switch works, and I don't know how to find a new one if it doesn't. Does anyone have a link to it as a spare part?
Also, I haven't checked the bulb - dashboard disassembly really scares me...
manosr is offline
post #14 of 41 Old 02-01-2020, 03:02 PM
Chrisnvegas
Chrisnvegas's Avatar
If anything happens to the firewall switch, scrap it and ebay a CAD switch that mounts to the axle. Extend the wire. The switch works as a ground for the dash light.
Pulling the dash bezel to inspect the light bulbs need not be scary. You aren't taking the dash apart, just removing a light weight bezel from the front.
Societies that are truly free can survive only if an open debate and an uncensored exchange of ideas can take place
Chrisnvegas is offline
post #15 of 41 Old 02-02-2020, 12:07 PM
manosr
I will check the bulb, what's the worst that can happen?
My issue remains: I'd like to find a vac firewall 4WD indicator switch, new. I don't know how...and believe me I have googled a lot...
(BTW thanks for all the replies!)
manosr is offline
4WD Indicator Lamp Switch???? louieberner YJ Wrangler Technical Forum 2 12-29-2009 07:43 PM
Help on a 4x4 indicator switch replacment phildaug TJ Wrangler Technical Forum 10 12-23-2009 02:24 PM
4wd indicator light switch ihategp YJ Wrangler Technical Forum 4 12-23-2008 12:24 AM
4wd indicator switch Brew461 TJ Wrangler Technical Forum 8 12-17-2008 12:44 PM
NP241J 4WD Indicator Light Switch joe130 TJ Wrangler Technical Forum 1 12-17-2008 08:55 AM
