4-Speed Transmission - JeepForum.com
 1Likes
  • 1 Post By Kzoldman
post #1 of 8 Old 09-24-2018, 11:53 AM Thread Starter
Kzoldman
After 30 years without one i'm loving being in the Jeep world again. My last one was a 79 CJ5. Can't post pics yet but will soon. I got my Jeep in June of this year. It is a 95 YJ with a 4 cyl. I appear to be the 5th owner on the car fax. The guy I bought it from said the previous owner had problems with the 5 speed transmission and when he swapped it out he put in a 4 speed. Nothing under the Jeep looks modified and it runs fine. Great gas mileage and the rpms are reasonable on the highway. I haven't taken it out on the interstate yet. Any thoughts on this? What transmission would have worked? Should I look at an upgrade? This will not be a rock crawler or mud crawler. Just a Jeep to ride trails and clear cut roads and some mud. Thanks!
Kzoldman is offline
post #2 of 8 Old 09-24-2018, 12:06 PM
jp360cj
1977 CJ7
4 speed manual or automatic? Going to be tough to ID the transmission without pictures or at least casting numbers. If you can upload pics to a host site and post the URL, one of us will link them for you.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #3 of 8 Old 09-24-2018, 12:10 PM Thread Starter
Kzoldman
Manual. I will see if i can find numbers this afternoon.
Kzoldman is offline
post #4 of 8 Old 09-24-2018, 02:00 PM
timatoe
timatoe's Avatar
Perhaps it's the rarely heard of AX-4.
Originally Posted by Advanced Adapters
It should also be noted that Jeep did offer a 4 speed version of the AX5 referred to as the AX4.
http://www.advanceadapters.com/tech-...-transmission/
If it suits your needs I wouldn't worry about it, if you get itching for a change to a 5 speed, I'd skip the AX-5 and swap in a AX-15 instead.
timatoe is offline
post #5 of 8 Old 09-26-2018, 07:44 PM
steeve555
Maybe its an AX5 that lost 5th gear. Very common problem
steeve555 is offline
post #6 of 8 Old 10-03-2018, 01:42 PM Thread Starter
Kzoldman
After looking over trans and doing some reading the ax4 is externally the same as an ax5. Didn't see any numbers. You can put it into 5th going down the road but its like putting it into neutral. So for now, it's 4 speed Jeep with me looking for 5th out of habit 😊
bharris68 likes this.
Kzoldman is offline
post #7 of 8 Old 10-03-2018, 05:40 PM
bharris68
Gravel Truck Pilot
There are a number of replacements for the AX5 behind the 4 cylinder, I believe
bharris68 is offline
post #8 of 8 Old 10-03-2018, 07:31 PM
steeve555
There are threads telling how to fix 5th gear. There is also a fix for the problem. Problem is a snap ring popping out. The fix is put snap ring back on and install a collar over it.
transmission
