4.2 to 4.0 swap? - JeepForum.com
post #1 of 12 Old 04-23-2019, 08:57 PM Thread Starter
Robbiescd
Robbiescd's Avatar
1987 YJ Wrangler
4.2 to 4.0 swap?
I’ll go ahead and apologize for the threads. My wife says I overthink everything!
As most of you may have read, I have a cracked block. Found a block for $50 so now I have to rebuild.
While looking around locally, I came across a 4.0 that “started smoking” and is for sale. $200 asking or best offer. Is it worth trying to go to the 4.0 vs the 4.2 rebuild? My biggest concern is the electrical. I’m not good at all on the electrical side. My 4.2 currently has the Mopar EFI on it. Spoke with Hesco and they said I would need a new exhaust manifold, but it should work with the 4.0.
My question is, from a cost and modification perspective, is it worth it? Or should I just continue down the road of rebuilding the 4.2?
Robbiescd is offline
post #2 of 12 Old 04-23-2019, 10:43 PM
timatoe
timatoe's Avatar
I'd keep the 4.2 and do the 4.0 head swap when rebuilding.
timatoe is offline
post #3 of 12 Old 04-23-2019, 10:45 PM Thread Starter
Robbiescd
Robbiescd's Avatar
1987 YJ Wrangler
Thanks. That’s where I’m leaning also. I’m going to see if he will just sell the head. He may not. Don’t want to get too deep in the pocket book on this.
post #4 of 12 Old 04-23-2019, 10:50 PM
timatoe
timatoe's Avatar
Right and $200 for a smoking motor isn't a good deal IMHO. If it came with the CPU and harness etc, then yeah.
timatoe is offline
post #5 of 12 Old 04-24-2019, 05:32 AM
Que89YJ
x2 with the 4.2L rebuild. You're going into the rebuild with everything working except the engine. Deal with the devil you do know. Modding is fun to do when you want to, you are dealing with getting it back on the road which is a have to do.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #6 of 12 Old 04-24-2019, 08:58 AM Thread Starter
Robbiescd
Robbiescd's Avatar
1987 YJ Wrangler
Good point. I just figured since I had everything out in the open, now would be the time for a possible head swap. But reading his description, it kind of scares me (attached). And I can’t find any other 4.0 heads around. He doesn’t want to part it out, and Wants me to make an offer. Salvage yard wants $200 for the head.
post #7 of 12 Old 04-24-2019, 09:36 AM
Que89YJ
The 2002 4.0 head was known to have issues. Have you tried using search tempest or car-parts.com?
Fault codes:
No Start:
Que89YJ is offline
post #8 of 12 Old 04-24-2019, 10:42 AM
HAZCAT
HAZCAT's Avatar
I am in the process of doing a 4.2 to 4.0 swap and it isn't that hard and worth while.....BUT...the main reason is to get a fuel injected motor and not spend money fixing up an old carb motor.....or Renix system...you have injection and the 4.2 has more low end torque and frankly I like it better. Which is why my 4.2 will not be leaving my shop and I will save it for another project....
Keep the 4.2 and build it....that is the smart money!!!
'84 CJ7, 44, 14 bolt, twin stick 300, 109"whl base, 4 linked
'93 XJ Cherokee
'70 CJ6 Dauntless v6
HAZCAT is offline
post #9 of 12 Old 04-24-2019, 12:54 PM Thread Starter
Robbiescd
Robbiescd's Avatar
1987 YJ Wrangler
Thanks for the replies. I think your all dead on. I’m just going to get this 4.2 up and running and save my money to one day swapping the old ba10 transmission. I love the low end torque I have, but going up hill on the highway kills me. 5th gear is only for flat roads or going downhill! I’m running 33x12.5x15. Passing a vehicle....forget about it.
post #10 of 12 Old 04-29-2019, 02:49 PM
CSP
Sounds like you may have the wrong axle gears for the tire size. Can't blame that on the transmission.
CSP is offline
post #11 of 12 Old 05-02-2019, 09:52 PM
Mechman71
Eh, 5th is pretty tall in the BA10/5, especially with the factory 3.07's. I had the same issue when I was running 29's, 5th was for flat highway cruising, downshift to pass or climb. It IS a tiny bit worse now that I'm rolling on 31's (that's about what my current tires measure out to), but the difference is really negligible. Anything below 65mph and I'm in 4th.
'89 YJ "Night Eagle" 4.2 5spd, Spinnaker blue/grey, hard top and doors, mostly stock and RUST FREE!!
Mechman71 is offline
post #12 of 12 Old 05-03-2019, 12:39 PM Thread Starter
Robbiescd
Robbiescd's Avatar
1987 YJ Wrangler
Same with me. Below 60, 4th gear. Above 60 and when going downhill, I can go 5th. Or if on flat grade. Would have liked to have gone with smaller tires/wheels, but I couldn’t pass up the price. May be an upgrade in the future.
87 4.2 to 91 4.0 swap lthays YJ Wrangler Technical Forum 39 05-14-2019 12:37 PM
4.0 swap McSyd Jeep CJ Forum 24 04-08-2019 11:16 AM
Need help swap out a 90 4.2 to a 95 4.0. Looking for advise on wire harness Repobandit YJ Wrangler Technical Forum 5 04-13-2018 11:39 AM
4.2 to 4.0 Swap - Accessory Mounting kevrags YJ Wrangler Technical Forum 0 03-23-2018 02:43 PM
4.0 Engine Swap Complete trwedgn YJ Wrangler Technical Forum 1 03-11-2018 09:20 AM
