4.2 to 4.0 stroker and BA10 to AX15 swap - JeepForum.com
post #1 of 9 Old 12-04-2011, 11:35 AM Thread Starter
mdemieville
Hey guys, here is the deal. My 4.2 has 170,000 miles on it and needs rebuilt pretty bad. Valve guides are leaking, rings are getting some blow by, and she has the rear main seal leaking again. I wanna go fuel injection anyway so I'm gonna be doing a 4.0 swap no matter what. I will be getting a running vehicle when its time to do the swap, probably a Cherokee, so I can grab everything at once. I plan to do a rebuild on what ever motor I get anyway so while I have it apart is it worth it to swap in the crank and rods from the 4.2? I know I would have to have the rotating assembly balanced and I'm ok with that. If any one has any experience with the swap please chime in.
At the same time I do the engine swap I plan to rebuild and install a 1991 AX15 trans that I have sitting around here at the house to replace my puke-o trans that's in there now. So my question is this....which pilot bearing will I need if I do the stroker? I know that I will have to change the input shaft on the transfer case and plan on stealing the one out of the cherokee that I get for the swap, but haven't seen much on the pilot bearing. If I remember right the 91 AX15 has a smaller snout and I would need one for the 4.2 crank. Thanks for any help guys.
Mark
mdemieville is offline
post #2 of 9 Old 12-04-2011, 11:42 AM
jsawduste
2006 YJ Wrangler
jsawduste is offline
post #3 of 9 Old 12-04-2011, 02:14 PM Thread Starter
mdemieville
I looked there and didn't see too many people who had gone from the 4.2 to the stroker. Almost everyone went from the 4.0.
post #4 of 9 Old 12-04-2011, 02:54 PM
dillonjm
dillonjm's Avatar
2013 WK
There's no differnce except you need to find a computer, wiring, sensors, etc from a 4.0 as well as a complete 4.0 engine that you can build with your 4.2's crank and connecting rods (IIRC).
You end up with the same thing, a 4.0 block with some bigger injectors that holds some 4.2 parts. If I remember from my research correctly, everything from the flywheel back should be the stock stuff from the Cherokee then mated to your axles via whatever driveshafts you desire. You'll have to clock the t-case, you can find more info on this in the AW4 swap threads.
JEEPLESS
Past Jeeps: 13 GC, 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #5 of 9 Old 12-04-2011, 03:31 PM
jsawduste
2006 YJ Wrangler
That`s what you are doing if you get an XJ and rebuild the 4.0 engine and use your 4.2 crank. The XJ FI setup and associated wiring.
Make sure you get the correct pistons so your quench height is 0.
If you plan on using your 4.2 crank/rods and pistons. Don`t bother to build it.
post #6 of 9 Old 12-04-2011, 04:47 PM Thread Starter
mdemieville
I guess one of my biggest questions is how much of a power and torque difference is there between the 4.2 and the stroker? If it is minimal I will just EFI the 4.2.
post #7 of 9 Old 12-04-2011, 04:49 PM
dillonjm
dillonjm's Avatar
2013 WK
Its significant. The 4.0 puts out more power than the 4.2 stock to stock and its a decently big jump from the 4.0 numbers.
Take a look at this site:
http://www.jeep4.0performance.4mg.com/photo3.html
He has some "formulas" for different stroker builds with some numbers to go along with them toward the bottom of the page.
JEEPLESS
dillonjm is offline
post #8 of 9 Old 12-04-2011, 06:20 PM
jsawduste
2006 YJ Wrangler
Originally Posted by dillonjm View Post
Its significant. Take a look at this site:
That`s Dino`s site. He is from the Desert Countries. While he has some good information. The HP/Torque numbers are simply estimates pulled from an ancient computer simulation program. Not proven dyno tests.
I would caution any of the low buck builds. Much of the information is conjecture and/or simply wrong. While the parts will go together you will likely end up with mediocre results.
One of the best articles written lately is the stroker series in JP magazine. Where they take a tired 4.0 and replace it with one of the MOPAR stroker engines directly from Chrysler. Here they give some real world information and driving impressions.
http://www.jpmagazine.com/techarticles/engine/154_1107_weekend_mopar_47_stroker/index.html
http://www.jpmagazine.com/techarticles/engine/154_1111_mopar_stroker_motor_part_2/index.html
http://www.mopar.ca/en/accessories/blockscrateengines.php
The stroker from MOPAR doesn't follow any of Dino`s build recommendations.
post #9 of 9 Old 12-04-2011, 07:24 PM
dillonjm
dillonjm's Avatar
2013 WK
Interesting read. Thanks for the link.
I've been reading a little bit about stroking a 4.0. I think I'm going to eventually try it once my motor gives up the ghost. It still runs great.
JEEPLESS
dillonjm is offline
4.5 stroker , 4.6l stroker , 4.7l stroker , trans swap
ba10 to ax15 swap, what input gear???? 88yj2008 YJ Wrangler Technical Forum 5 03-07-2011 08:04 PM
BA10 to AX15 swap question 88YJtoCJ YJ Wrangler Technical Forum 10 05-21-2009 01:11 AM
what modifications are needed to swap Ba10 for AX15 BA-YJ YJ Wrangler Technical Forum 13 06-23-2008 10:16 AM
Pros & Cons To Swap A Ax15 Or Nv3555 What It Is Better To Take Out Ba10/5 Fed YJ Wrangler Technical Forum 3 10-02-2007 07:00 PM
BA10 to AX15 swap? 1NastyZ06 YJ Wrangler Technical Forum 5 01-09-2006 02:48 PM
