4.0 compatibility - JeepForum.com
post #1 of 7 Old 06-21-2021, 10:17 AM Thread Starter
Derekwh
Derekwh's Avatar
4.0 compatibility
I have a '91 Wrangler with a seized 4.0, would a 4.0 from an '03 Grand Cherokee work as a replacement? I would need to keep the '91 smog equipment to pass California smog.
Derekwh is offline
post #2 of 7 Old 06-21-2021, 10:24 AM
Randonexplosion
Randonexplosion's Avatar
I'm pretty sure that there are some significant differences in the block on the Grand Cherokee motors like the motor mount bracket locations. I think XJ and TJ blocks are going to be more compatible.
Whoever appeals to the law against his fellow man is either a fool or a coward,
whoever cannot take care of himself without that law is both.
For a wounded man shall say to his assailant "If I live I will kill you, if I die you are forgiven". Such is the rule of honor - Omerta
Randonexplosion is offline
post #3 of 7 Old 06-21-2021, 11:48 AM Thread Starter
Derekwh
Derekwh's Avatar
Thanks
Derekwh is offline
post #4 of 7 Old 06-22-2021, 01:55 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
Find a 1991 - 1997 Cherokee 4.0 long block (head and block) in working order. Remove all the accessories like the water pump etc. Install the long block with all your original accessories. FIX whatever cooling issue or other issue(s) you had that seized the block, and you should be good to go.
If you are in So Cal, hit up Inland Jeep for a running long block. Shawn is a good guy there and we have used a few of his motors on projects.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #5 of 7 Old 06-22-2021, 07:08 PM
Boojo35
1987 YJ Wrangler
My knowledge is that there is a significant difference in the block where the AC compressor mounts on 4.0L engines and it matters from the Grand cherokee to the others IIRC. Year of the block may factor in. There may be other differences but this is the big one that I know of.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #6 of 7 Old 06-23-2021, 09:28 AM
jbolty
Administrator
jbolty's Avatar
I have zero experience with this but did they really make a different block casting from the original 4.0 we all know about?
jbolty is offline
post #7 of 7 Old 06-23-2021, 11:49 AM
Randonexplosion
When I was ordering a long block for a 1999 TJ I had to be very specific about the A/C compressor location.
