JeepForum.com (https://www.jeepforum.com/forum/)
-   YJ Wrangler Technical Forum (https://www.jeepforum.com/forum/f12/)
-   -   35x12.50 R15's on stock rims -- what could go wrong? (https://www.jeepforum.com/forum/f12/35x12-50-r15s-stock-rims-what-could-go-wrong-4379779/)
inductiveload 12-07-2019 01:54 AM
For one thing I am pretty sure that these tires have been put on the Jeep without a lift kit. So clearance is an issue.
Turn radius is another .. the tires rub on the spring. That is super annoying. :D
That said, what I am really struggling with is understanding what I have been reading about regarding the rear axle being stressed by the 35's. What forces are in play and why are the tires putting stress on the axle? If 35's are too big then what is the max tire size if everything in the drivetrain is stock?
I do have to shift out of 5th while on the highway to keep from dropping in speed.
fishadventure 12-07-2019 07:50 AM
The rear axle shafts and ring-and-pinion experience a ~50% or more in simple leverage increases from the larger tire size.
The axles and R&P are somewhat adequate for the 215-75-15s stock tires but general consensus is that it’s weaknesses show up readily off road with tire sizes above 33”. (I feel I was fortunate to go almost 300K miles with my D35 with all the towing I did but it was 2.5/4-cyl and so it never experienced much heavy torque.)
As far as stock wheels and 35s: depending on year stock wheels are 6-1/2” or 7”. I don’t think there was a factory 8”? - not sure. Anyway, a 12.50 tire wants an 8” to 10” wheel. On a jeep I think 8” provides adequate width and tire profile benefits. I don’t know of any steel 8-1/2” wheels for a jeep. I looked s year or two ago.
A 12.50 on a 7” wheel is going to balloon and center-ride toomuch imho - and not be nice off road or on road (my 11.50s on 7” are too ballooned for my taste but they've worked ok)
80cj 12-08-2019 10:38 AM
Too narrow a rim also causes the tire to buldge and causes steering clearance issues. Something like a 10" rim has sufficient offset to place the additional width of the tire toward the outside thereby allowing more clearance between the tire and frame.
sptrmike 12-08-2019 12:08 PM
When I bought my heep I did a long search for info on the stock axles. I found a web site with the Dana specs, it gave the max tire size for the 30 is 33" and for the 35 the max tire size is 31". I've been wheeling with 32's for 11 years with no problems, BUT I don't have stock shafts or carrier, I'm careful with wheel spin and not concerned about pulling cable. That being said I have a 8.8 in the garage that I hope to have installed by the spring.
Chrisnvegas 12-08-2019 04:38 PM
There goes the sidewall... POP!
That size tire on a narrow wheel:
1. Looks retarded.
2. Exposes the sidewall to sharp rocks.
timatoe 12-11-2019 06:26 PM
I believe the stock wheels are 7", 8 - 8.5" is about perfect in my opinion for a 12.5, 10" is too wide and is more apt to bead loss when aired down under about 12 psi (especially so on aluminum wheels).
The D35 is just weak in general. I personally would not put any money toward trying to strengthen it when there are far superior options available for the same or less money.
Side note... What part of OK are you from?
inductiveload 12-12-2019 11:36 PM
Guys .. thanks for all the comments and observations! It helped out a ton.
:thumbsup:
Yukon. The YJ is mostly a hanger queen right now since she is still wearing a bikini top and I gotta get the headlights fixed. Plus I have some red dirt that I need to get washed off of the chassis. Thought that I got it all with the first wash.
:D
timatoe 12-13-2019 09:00 PM
:thumbsup:
:D
:wave: I was born in Moore, went to High School in Midwest City, lived in Mustang before moving back to CA in the late 90's. My mom and sister both live in El Reno.
inductiveload 12-23-2019 12:39 PM
Sweet. My wife and I have been in Oklahoma since 1998 and we love it here. A relative inexpensive cost of living and college football .. life is good. :D
The time now is 10:57 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
