258 Engine rebuild ... Oil fouling Cyl #1 - JeepForum.com
 1Likes
  • 1 Post By fishadventure
post #1 of 6 Old 08-02-2021, 04:15 PM Thread Starter
jimsahm
I rebuilt my 258 from an '89 YJ. All seemed to go well...engine started fine (GM TBI Mod)...did proper 2k rpm for 20 minutes... Then ran gently through the farm country here...up and down hills...engine braking going downhill...no jack rabbit starts...etc... Cylinders 2-6 are 100% fine. Cylinder #1 is apparently oil fouling. Worse at idle and than with throttle...blows blue smoke (oil burning smell)... It has only about 90 or so miles on it now...Plug from #1 oil fouled...shiny, oily...Plugs 2-6 are all light tan--normal...By 50 miles, plug #1 fouled to a no spark condition.
I bore-scoped the cylinder walls and compared #1 to #2... about the same...still cross-hatched and seemingly ok...some vertical scratches...nothing deeper than honing marks. Noticed oil puddle on #1 piston at about 50 miles...Apparently will burn off on running...
No blue smoke while running at road speed. Stop for a light and there is a blue smoke at throttle application.
EDIT: Compression test shows 149-150psi across all cylinders.
I am thinking the following:
1. Oil rings not seated yet and this cylinder is taking longer for some reason.
2. Oil rings defective or installed wrong.
3. Compression rings installed wrong.
4. Thought it was maybe valve seals....replaced and zero difference.
Anyone have some advice? Thinking of pulling out cylinder #1, re-hone, re-ring....and try again... OR preferably someone tell me that the rings are just not seated yet....
Ideas??
Thanks,
Jim
jimsahm is offline
post #2 of 6 Old 08-03-2021, 12:02 PM
fishadventure
fishadventure's Avatar
Oil drip on piston: rings can’t drip
No smoke running: positive pressure
Smoke at idle: high vacuum
Good compression. Probs not rings
Valve guide worn is my first thought
Someone remind me or correct me: is cylinder #1 the one that needs a head bolt sealed with RTV? Or am I confused?
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #3 of 6 Old 08-03-2021, 08:49 PM
Azhunter1
Azhunter1's Avatar
Yes cylinder 1 drive side bolt number 11 needs to be coated with sealant. Valve guides is my thought too or a worn valve.
Azhunter1 is offline
post #4 of 6 Old 08-04-2021, 05:37 AM
fishadventure
Well I think you know what to explore.
Good (dry) compression gives an indication that the short block is probs ok. The head bolt, gasket, or valve/valve guide is all that’s left for your exact fresh rebuild symptom imho
post #5 of 6 Old 08-04-2021, 08:16 PM
Azhunter1
Azhunter1's Avatar
Isnt the #11 head bolt coated because of how close it is to the water jacket?
post #6 of 6 Old 08-05-2021, 04:21 AM
fishadventure
Yes, and- I may be wrong- but I think it’s running through antifreeze in the middle and crankcase on the bottom?
I actually can’t remember, just that there’s a cruddly one
Azhunter1 likes this.
