1995 Wrangler Speedometer not working - Page 3 - JeepForum.com
post #31 of 44 Old 05-09-2014, 09:22 PM
Redqman
I do have a meter and these are the codes that come up. I understand only the 15 lights the light. there is no AC.
12* Direct battery input to PCM was disconnected within the last 50 key-on cycles.
15** No vehicle distance (speed) sensor signal detected during road load conditions.
33* An open or shorted condition detected in the A/C clutch relay circuit.
Redqman is offline
post #32 of 44 Old 05-09-2014, 09:22 PM
Redqman
the key is off
Redqman is offline
post #33 of 44 Old 05-10-2014, 06:22 AM
XJ93
XJ93's Avatar
Does the gauge ever move from that position? Check grounds. If those are fine then it's possible the gauge itself is shot. My speedo quit qorking over a year ago. I finally got it working by reclocking it. Instead of my tooth number being at 6 o'clock it's at 9 o'clock. Check that as well, but if the ecm says no input and yet the gauge is pegged I would first check the grounds, including the ground wire for the vss itself.
XJ93 is offline
post #34 of 44 Old 03-09-2015, 09:40 AM
hughar
1995 wrangled when purchased speedometer not working. Unplugged from transfer case. Plugged in and dash lights and hazards flashing, with no power at ignition. Jumped off at starter and ran and speedometer worked. Only way to stop flashing was unplug from transfer case. Has a short could it be at it be at VSS?
hughar is offline
post #35 of 44 Old 03-09-2015, 09:50 AM
Que89YJ
You should post up a new thread. If you disconnect the VSS the short can be through the VSS. I don't know how the short could be doing what you describe.
Que89YJ is offline
post #36 of 44 Old 10-28-2019, 06:08 PM
yarboroughjd
Sensor bad or electrical issues ive replaced the sensor in my yj and still haven't had any luck. wire test is as follows Turn ignition switch to ON position. Raise vehicle. Disconnect distance (speed) sensor connector. Check black wire at sensor connector for voltage. If voltage is about 5 volts, perform distance (speed) sensor test.
If voltage is not as specified, turn ignition switch to OFF position. Check continuity between instrument cluster connector terminal No. 13 (White/Orange wire) and distance sensor connector. If continuity exists, replace speedometer. If no continuity exists, repair open in White/Orange wire.
yarboroughjd is offline
post #37 of 44 Old 02-20-2020, 01:07 PM
aeason0405
I have a 95 jeep YJ speedo that did not work maybe a short time then nothing. I was a dodge tech their is nothing wrong with the meter . behind the meter their is a connector and just below that one is a other. you will have to buy a plug connecter kit. snap-on tools have this kit. its not much at all. they look like a very small flat screw driver set . each one has a different color , red blue green yellow and some other colors in the kit. you will have to remove each pin from the connector take your time with this project ! after removing one pin at a time lightly sand the pin with 400 grit sandpaper .use these tools to tighten the connector to make a better connection. its takes time but its not hard . if your dash lights don't work or the volt meter doesn't work the connector on the dimmer switch is the problem . the connector on the back of the volt meter this is your problem
aeason0405 is offline
post #38 of 44 Old 02-20-2020, 06:45 PM
dshot59
Speakin of spedo issues, My 93 spedo works but reads way fast like 10 plus mph.I just got this one and have no idea what was done to it before I got it any thoughts on that one anyone ?
When in doubt and you can't figure it out, Stand on it !
dshot59 is offline
post #39 of 44 Old 02-23-2020, 02:09 PM
NHfireLJ
NHfireLJ's Avatar
Pull the speedo gear and see what size it is...
tire size you are running?
Probably wrong gear in there...
AUDREY...95 YJ UNLIMITED LS
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
SOLD
BETTY...94, Stroker 4.6,35"s, SOLD
style intake
NHfireLJ is offline
post #40 of 44 Old 02-23-2020, 06:47 PM
dshot59
It's on 31-10.50's I thought about the gear too but couldn't figure why someone would just change the gear. The case maybe if it got wiped out . It's not even close to being right though.
dshot59 is offline
post #41 of 44 Old 02-23-2020, 06:53 PM
NHfireLJ
NHfireLJ's Avatar
Just check it...
Then look here. https://www.quadratec.com/c/referenc...ar-tooth-chart
SOLD
style intake
NHfireLJ is offline
post #42 of 44 Old 02-23-2020, 07:13 PM
dshot59
Thanks much, will do. Here's the pic I finally got it to load up/
dshot59 is offline
post #43 of 44 Old 02-23-2020, 07:15 PM
Awesome
Awesome's Avatar
It's on 31's. The 2.5 probably came with like, 28" tires or smaller. That would definitely make the speedo be off by 10mph or more.
The 4th 5-seater YJ in the world.
Awesome is offline
post #44 of 44 Old 02-29-2020, 07:21 PM
dshot59
Yea but mine reads faster then I'm actually going.
dshot59 is offline
odometer , speedometer , wrangler
Speedometer not working..... youngjeeper11 YJ Wrangler Technical Forum 7 10-13-2012 12:12 AM
Speedometer not working w9kh_kevin TJ Wrangler Technical Forum 3 10-19-2009 06:17 PM
1995 YJ 4x4 not working underpowered YJ Wrangler Technical Forum 13 10-10-2008 11:28 PM
Speedometer not working on 87 Wrangler 89 JeepYJ YJ Wrangler Technical Forum 5 03-20-2008 06:28 PM
Speedometer not working Cross Eyed TJ Wrangler Technical Forum 1 01-31-2006 05:06 PM
