1995 oil pan gasket and valve cover gasket leak - JeepForum.com
 2Likes
  • 1 Post By Siva283
  • 1 Post By bruinjeeper
post #1 of 7 Old 08-22-2019, 05:05 PM Thread Starter
jacobowens1994
Hello all new to the forum just got my new wrangler home tonight and am wondering how difficult it is to change the oil pan gasket and valve cover gasket they both look fairly simple! Just curious if thereís any pointer for this job
Sent from my iPhone using Tapatalk
jacobowens1994 is offline
post #2 of 7 Old 08-22-2019, 09:05 PM
BChamberlin
BChamberlin's Avatar
You sure itís leaking at the oil pan and not the rear main seal? The oil pan is pretty simple. The rear main can be done as well, you just have to be really careful. Another guy in the forum has been doing a RMS so there is info there on it.
1994 Wrangler YJ
1999 Wrangler TJ [R.I.P.]
2008 Wrangler X
BChamberlin is offline
post #3 of 7 Old 08-22-2019, 09:56 PM Thread Starter
jacobowens1994
Not 100% sure Iím going to clean it up real good and pinpoint where itís coming from. Thanks for the reply!
post #4 of 7 Old 08-23-2019, 06:40 AM
Siva283
Siva283's Avatar
The rear main seal is a pain in the ***. It took me 3 to finally get it. Though the first one I put in half asleep and the second in the dark. The 3rd one I used dish soap to coat the top and loosened all the main bearing caps. Seems good not. The oil pan is a cake walk. The valve cover you have limited room. Rear main seal and valve cover is very common to leak. Your will replace the oil pan anyway when you do the rear main. Any time you replace the oil pan gasket you may as well do the rear main as they only seem to last about 50,000 miles generally.
jacobowens1994 likes this.
Ask me how I know...
Siva283 is offline
post #5 of 7 Old 08-23-2019, 09:03 AM
Feetwet
Enjoying the Ride
Feetwet's Avatar
Where does the OP say what engine he is working with?
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is offline
post #6 of 7 Old 08-23-2019, 06:19 PM Thread Starter
jacobowens1994
Itís the 4.0l inline 6
do I have to drop the tranny?
post #7 of 7 Old 08-23-2019, 07:05 PM
bruinjeeper
bruinjeeper's Avatar
With the 4.0. No ...you do not. It's a two piece seal. It can be finagled in without pulling the trans.
As for the oil pan and valve cover. In terms of gaskets, two of the easier ones to replace
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
~YJOTM JULY '19~
bruinjeeper is offline
