1994 YJ drivetrain swap question - JeepForum.com
 1Likes
  • 1 Post By Waternut
post #1 of 8 Old 05-26-2021, 11:16 AM Thread Starter
wminmi
Hello all -
I have a rolling chassis 1994 YJ that originally came with the 2.5 engine and 5-speed transmission.
I have a 1990 YJ donor Jeep with the 258 6-cylinder and auto transmission.
What all would I be looking at to swap the '90 258 engine and auto transmission into the '94 roller?
Pic is what I have, the black one is the donor.
Thanx in advance
2001 TJ 2.5, 5-speed
1994 YJ (roller project)
1990 Wrangler Laredo, 4.2 auto (donor)
wminmi is offline
post #2 of 8 Old 05-26-2021, 11:34 AM
Randonexplosion
Randonexplosion's Avatar
Several issues there but mostly its not a good idea. When I had the carbed 258 I wished I had the 2.5. At least its fuel injected.
Motor mounts need to be cut off and new welded on as well as wiring work.
It would be as much work as a 4.0 H.O. or a V8 but with disappointing results IMO
Sent from my SM-N986U using Tapatalk
Whoever appeals to the law against his fellow man is either a fool or a coward,
whoever cannot take care of himself without that law is both.
For a wounded man shall say to his assailant "If I live I will kill you, if I die you are forgiven". Such is the rule of honor - Omerta
Randonexplosion is offline
post #3 of 8 Old 05-26-2021, 11:44 AM
cpia84
cpia84's Avatar
First off you need to ask yourself: Are you going to keep the Jeep stock/stockish? That will determine what direction you should go with.
I am going to agree with @Randonexplosion If you are going to do a swap then either swap another 2.5 into the Jeep for an easy swap or if you want to do an upgrade go to a 4.0L HO or V8. You would also need to consider what transmission you would be upgrading to.
YJOTM: Jan 2021
cpia84 is offline
post #4 of 8 Old 05-26-2021, 12:38 PM
Randonexplosion
It is also against federal law to swap an older engine into a newer vehicle, so depending on your situation with inspections etc. that could cause some issues.
post #5 of 8 Old 05-27-2021, 01:39 AM
SevenSlotAddict
I dont know whats wrong with the black one, I assume its rusty? You may be better off reworking it using the red ones parts.
On a side note, I would be interested in left over parts, especially gauges. Shoot me a PM when you figure out what you wont reuse
Good luck!
SevenSlotAddict is offline
post #6 of 8 Old 05-27-2021, 06:05 AM
ayelander
ayelander's Avatar
It is also against "federal" law to swap an older engine into a newer vehicle, so depending on your situation with inspections etc. that could cause some issues.
Hopefully you meant "State" law.
93 CTYJ, 350 Chevy, SM465, NP 231J TC, Ford 8.8 Rear, D30 with Chromoly, 4" RE Spring lift, 5/8" Boom, 1" body lift, 35" MT's
ayelander is online now
post #7 of 8 Old 05-27-2021, 06:45 AM
Waternut
Waternut's Avatar
The engine swap law regarding swapping an older engine into a newer chassis is an EPA law. The fine is $2500 and it's all about emissions. So realistically, if you don't have emissions no one would ever know. You could swap the vin plates and comply with the EPA law but that's vin tampering and comes with a bigger fine if someone finds out. I seriously doubt anyone would know about that either but if you ever sell it, you may open up a big can of worms.
IMO, if you want the black Jeep's guts in the red Jeep, the easiest way is to swap the body. If you want the axles too, swap them as well. Boom, engine swap done in a day!
Randonexplosion likes this.
Waternut is online now
post #8 of 8 Old 05-27-2021, 03:24 PM
Randonexplosion
Like @Waternut said. It is an EPA thing, so its federal. Lots of guys swap in older 350s though
