1992 Jeep wrangler clutch - JeepForum.com
post #1 of 1 Old Today, 08:29 PM Thread Starter
Jazzblues
Hi,
I have a 1992 jeep wrangler. For a while now, the clutch pedal loses some of it pressure and Iím used to add some fluid inside the clutch fluid tank. I have never really looked at the issue and I have no idea why I have to add fluid, there is no leaks on the ground so Iím not sure what is happening to the fluid.
1. The longer I drive on the highway (longer distance, higher gear, no shifting), the more the issue is pronounced. Loss of pressure at the clutch pedal
2. As I come to more traffic and needs to slow down, shifting gears, I can distinctively feel less pressure on the clutch pedal, having to press nearly to the floor before I can shift. This happens if I drive for a long stretch without using the clutch (highway). By ďpumpingĒ the pedal with my foot, I can increase the pressure some.
3. I opened the fluid tank, there was a rubber membrane inside. I noticed some fluid below the membrane and none above it. Is this normal?
4. I filled the clutch fluid tank until it was full and by installing the cap, I notice there is a small hole at the center of the cap and some fluid coming out of this hole. Is this hole supposed to be there? Looks perfectly centered to the cap.
5. Should there be fluid above the membrane?
Any other suggestion you might have will greatly help me troubleshoot and hopefully solve it.
Thank you very much.
Jazzblues is online now
Jazzblues
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
2012 Jeep Wrangler Unlimited Rubicon BigD97TJ Jeeps For Sale 2 05-24-2018 04:26 PM
Wanted: Right Hand Drive Jeep Wrangler BarbadosMike Wanted 2 02-13-2018 06:38 PM
What People are Saying About the 2018 Jeep Wrangler JL AutoGuide.com JeepForum Announcements 0 12-05-2017 01:03 PM
