1992 2.5L Overheating - Page 2 - JeepForum.com
post #16 of 25 Old 05-02-2015, 12:43 PM Thread Starter
Scarface6174
Scarface6174's Avatar
The stock thermostat is 180. I think. Either way, it's a 180 thermostat and it's working as intended. Opening and closing at that temp. I've read about how engine thermostats work, crossed that with my dad, and it seems to be working as intended.
But I'm not closed off to other opinions.
Scarface6174 is offline
post #17 of 25 Old 05-02-2015, 07:14 PM
sonharleyjeep
I think I read YJ should be at 190. You might actually be cool.
sonharleyjeep is offline
post #18 of 25 Old 05-03-2015, 05:58 AM
fishadventure
fishadventure's Avatar
195 is correct
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #19 of 25 Old 05-03-2015, 10:20 AM Thread Starter
Scarface6174
In that case I'm good. Cause it hovers between the 210 and 182 line. More towards the 182. So that's cool. *ba-dum-tiss*
post #20 of 25 Old 05-04-2015, 11:34 PM Thread Starter
Scarface6174
Ok, so I'll be replacing the radiator this weekend. Because I'm looking for a replacement and not an upgrade (even though I would love one) I'm thinking this one from autozone, or Amazon for $40 cheaper. I am using this vehicle mostly for my daily driver, and about once every month or so for going to the shooting range which does require some crappy dirt roads to be traveled.
I just want to run this by you fellas and make sure I'm not getting a dud. I also realize that 'dud' is up for interpretation.
post #21 of 25 Old 05-05-2015, 11:08 AM Thread Starter
Scarface6174
Well, I should probably have put the actual link for the radiator. Heh.
http://www.autozone.com/1/products/3...ium-b2101.html
post #22 of 25 Old 05-05-2015, 01:20 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
Originally Posted by Chrisnvegas View Post
Still better than plummeting to earth from 10,000 feet.
Hey now.. Some of us have plummeted to Earth from 10K feet more than a few times..
and there is NOTHING better...
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #23 of 25 Old 05-05-2015, 01:25 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
Just FYI - I used the same radiator in our 2.5L YJ and it's been perfectly fine for over 3 years now. You should be OK.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is offline
post #24 of 25 Old 05-05-2015, 01:40 PM Thread Starter
Scarface6174
That's what I needed to know. Thanks.
I've got a lot more stuff I'm doing to this thing to make it 'good' again. Should I just make a new post about all that stuff or just change the title of this one and add to it?
post #25 of 25 Old 05-05-2015, 02:04 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
You could start a "Build Thread" if you like, or if you have a unique issue(s) you are dealing with, you could start a new thread. I'd research the topic before posting a new thread though.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is offline
overheating
