1991 Yj ignition not turning. - JeepForum.com
post #1 of 7 Old 04-15-2019, 05:51 PM Thread Starter
im2boss4u
Hello Jeepers, Ive ran into a problem with my 1991 yj 4.0L inline 6. I tried turning my key the other day and it turned but it didnt do anything. Now when i try to turn it it wont budge. The steering wheel is also locked up and wont budge either. I tried wiggling it and moving the steering wheel, but nothing seems to work. Any ideas?
im2boss4u is offline
post #2 of 7 Old 04-15-2019, 06:14 PM
Brad Perryman
Can you get it into neutral? Try rolling it a bit.
Sent from my iPhone using Tapatalk
Brad Perryman is offline
post #3 of 7 Old 04-15-2019, 07:05 PM
Boojo35
You have two different complaints. If it turned and nothing happens is one complaint. Now it wont turn is another. The second complaint is a worn out key or cylinder.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is online now
post #4 of 7 Old 04-15-2019, 09:26 PM Thread Starter
im2boss4u
Now it wont budge at all even when i try wiggling it or moving the steering wheel.
post #5 of 7 Old 04-15-2019, 09:28 PM Thread Starter
im2boss4u
Its a manual. so i can shift into neutral no problem. There is no way i could roll it where its at right now.
post #6 of 7 Old 04-16-2019, 05:24 AM
Robbiescd
Robbiescd's Avatar
1987 YJ Wrangler
Agree with Boojo. Sounds like bad key cylinder. May also have bad wiring to starter. I can’t remember color, blue maybe, but I believe it should go to starter.
Robbiescd is offline
post #7 of 7 Old 04-18-2019, 01:22 AM Thread Starter
im2boss4u
Before I tear this apart, could it be anything else? Like i said before it did turn once but it didnt do anything and it would sit in place and i could rotate it freely. It would then get locked when put into the 'off" position or whatever.
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
'87 YJ ignition randomly cuts off Rod_Danglewood YJ Wrangler Technical Forum 12 11-21-2018 02:23 PM
Ignition and ign. key sometimes doesn't work muddflow ZJ Grand Cherokee Forum 19 11-05-2018 04:19 PM
Chasing Gremlins Nereussailor Jeep CJ Forum 11 09-01-2018 05:41 AM
03 WJ Ignition issue, wont start deoxys987 WJ Grand Cherokee Forum 6 08-14-2018 10:27 PM
