1991 YJ Engine swap - PCM / ECM question - JeepForum.com
 2Likes
  • 1 Post By TSEJEEPERS
  • 1 Post By Luuca
post #1 of 12 Old 05-24-2021, 07:12 AM Thread Starter
mudtug
Hi All,
I have a 1991 YJ that came with a 2.5L, AX-5, NP231. The Jeep runs great, but it is grossly underpowered with 4:10 gears and 33's. I have a 4.0L and an AX-15 (plan to use the existing NP231) from a 1997 TJ. I have the powertrain harness from the TJ (Cam position sensor, crank position sensor, O2 Sensors, etc.) from the front all the way back to Fuel pump/gauge and in between.
My question pertains to the PCM / ECM. Will the PCM from the TJ work with the YJ? I am thinking no, primarily because the dashes are so different, I know the TJ uses a digital 2-wire CCD communication to the gauges on the TJ instrument panel. Moreover, will the 2 YJ body harnesses work with the newer (97) PCM?
So, do I need to use the PCM from, say an 1987 YJ that came with a 6-cylinder? Can I use the PCM from the 1997 TJ in the 1991 YJ? Could use some guidance from those who have done this before (I will say the 1987 YJ's 4L had a carburetor and not a throttle body, so not sure it would work?)
Would appreciate feedback from those who have done this before, so I can track down whatever I need before I have another unfinished project in the shop!
I know I have to cut the 2.5L engine mounts and weld in new mounts for the 4L, no issues there. I believe I can reuse the skid plate I have that came in the 91 YJ (AX-5) and mount the AX-15 to it. I know I will need a new exhaust, no mechanical issues I can foresee. Just the PCM / ECM question.
Appreciate any knowledge the mechanical gurus can pass along!
Thank you,
Mudtug
mudtug is offline
post #2 of 12 Old 05-24-2021, 09:16 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
Originally Posted by mudtug View Post
Hi All,
Thank you,
Mudtug
Your 1991 has a mechanical speedo. Ours did.
The ECU you have will run the 6 cylinder. It is provisioned for the extra 2 cylinders. You can use your 91 engine bay harness and simply add the 2 necessary injectors. You will want to use the YJ sensors not the TJ sensors.
You can get two injector connectors from the Junk yard cheap, and wire them in. Below is a link to a PDF for the 1991 YJ FSM. look at the 6 cylinder wiring diagrams. You will need to extend the coil wires and the alternator wiring on the passenger side of the engine.
I was lucky to find an actual 6cylinder 1991 YJ engine bay harness when we did our swap, but I know all this can be achieved.
https://www.dropbox.com/s/xa98fp8pjb...%20SM.pdf?dl=0
Name:  i6 Fuel Injection.png
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #3 of 12 Old 05-25-2021, 04:38 AM
fishadventure
fishadventure's Avatar
@Luuca The 1991 2.5 ecu will run the 4.0?!! I didn’t know that!
OP: I used 1991 2.5 harness in my ‘89 and modified as luuca indicated to run a 4.0. Wasn’t hard to do.
1991 had/has a cable-drive speedometer that ALSO has an electronic speed sensor for the ecu. It will throw a code and usually trigger the CEL if it does not ‘see’ the speed (vss) sensor.
The YJ also has two engine temp sensors whereas tj has only one. One is for the gauge (in head) snd other is on the t-stat housing. There’s a couple of ways around this.
It’s a fun project imho
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #4 of 12 Old 05-25-2021, 11:48 AM Thread Starter
mudtug
That's great news! Thank you for the info.
When you say use the YJ sensors, I assume you mean swap over the Cam Position sensor, Crank position sensor, Throttle Position sensor? Anything else I need to move over to the 4L?
I fully understand grabbing the injector connectors/wires from the junk yard, will likely just yank those out of my donor motor harness.
As for the 97 4.0L only have the temp sensor in the thermostat housing, I am interested in any suggestions for cheating/working around the missing cylinder head temp sensor?
fishadventure, yes, should be a fun project, that YJ is pretty much unstoppable off road in low range, but getting there with those 33's I get a lot of waves from folks in such a hurry that they only wave with 1 finger! I think the 4L and AX-15 will coupled with those 4:10's should actually allow me to see the speedo actually rise in 5th gear!
Thanks again for the great info, very very helpful!
Mudtug
mudtug is offline
post #5 of 12 Old 05-25-2021, 12:46 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
Mudtug
I don't have any pictures on hand, but while we had the engine pulled, we drilled out and tapped the boss on the TJ engine to fit the YJ temp gauge sensor.
We removed the rear upper freeze plug from the head and ran a shop vac into that freeze plug while we drilled along with coating the drill bit and tap with red-tacky grease. We were able to simply thread in the factory YJ sensor when we were done.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is offline
post #6 of 12 Old 05-31-2021, 05:36 AM
fishadventure
I removed a 1/2” pipe plug in the block under the manifolds and threaded it into an adapter there. Thanks jsawduste
post #7 of 12 Old 08-01-2021, 09:03 PM
Mackie
fishadventure, can you confirm that the 2.5 ECM will run the 4.0?
Mackie is offline
post #8 of 12 Old 08-01-2021, 11:30 PM
Mackie
So you are saying an ECM from a 2.5 will work with a 4.0? Are you sure? I know the wiring harness is almost the same and the harness will work from the 2.5 with some modification, but I don't believe the 2.5 ECM will work with the 4.0..?
Mackie is offline
post #9 of 12 Old 08-02-2021, 05:04 AM
fishadventure
No, I cannot confirm that. @Luuca may have been referring to your reference of the tj ecm. I have not used tj components so I don’t know
A 1987 anything YJ will not work for you. MPFI came out in 1991- those ecm/ecu units will both plug into your 1991 harness.
However, to run a 4.0 from a post-1996 4.0 with a 1991 2.5 YJ harness straight up you need these things done:
1) add injector wires
2) move one or two wire locations in the 60-pin
3) move / make new motor mounts
4) add a second coolant sensor
5) if XJ 4.0 change out water pump, fan, some cast aluminum brackets, power steering pump etc from the XJ config to the 1991-1995 YJ config.
This involves of course adding two more injector wires to the 60-pin connector, plus one or two wires need to moved to a different position in the connector. Three wires needed to be extended iirc.
I don’t know if the TJ 4.0 has YJ water pump etc.; I think it does, but I don’t know.
@Luuca will have to confirm the tj ecm use as I haven’t stolen any tj 4.0s
(Since you’ll be making new motor mounts ‘my’ suggestion is to lift the motor and trans at the same time to get rid of the factory low-slung skid. However, this predicates an SYE, driveshaft, and floor pan mods as well as a new crossmember so maybe you don’t want to spend that much or bite off that much work.)
post #10 of 12 Old 08-02-2021, 07:40 AM
TSEJEEPERS
TSEJEEPERS's Avatar
What about the coil packs that the TJ motor uses?
Can you remove those and run plug wires and a distributor?
Luuca likes this.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #11 of 12 Old 08-02-2021, 10:46 AM
Randonexplosion
Randonexplosion's Avatar
The first few years of the TJ had a distributor.
Whoever appeals to the law against his fellow man is either a fool or a coward,
whoever cannot take care of himself without that law is both.
For a wounded man shall say to his assailant "If I live I will kill you, if I die you are forgiven". Such is the rule of honor - Omerta
Randonexplosion is offline
post #12 of 12 Old 08-02-2021, 02:52 PM
Luuca
Luuca's Avatar
1986 MJ Comanche
I can Confirm this. You can pull the coil packs off a TJ4.0 and run a standard distributor in the hole where the TJ has the OPDA. We have a 98 XJ that we did this on.
You can see the coil pack Bosses in the above pic.
Below is the engine with distributor and plug wires. I drove this Jeep yesterday.
TSEJEEPERS likes this.
91 YJ "Alice"
YJOTM Sept. 2017
Luuca is offline
