1991 jeep Wrangler gauge schematics & fix - JeepForum.com
post #1 of 4 Old 05-25-2020, 02:33 PM Thread Starter
DRoness
I am trying to get my gauges to work on my 1991 Jeep Wrangler and I have no power to my pink wire which goes to #7 and #4 brown and black stripe wire, on the wire cluster which plugs into the back of my gauges (clock, oil, fuel etc). I need to replace those 2 wires and need to know where they go. Thank you in advance for any help.
DRoness is offline
post #2 of 4 Old 05-26-2020, 12:35 PM
11-11-11
11-11-11's Avatar
Remove and check the IGN-LPS fuse on the fuse panel (lower right). A blown fuse or dirty contacts on a good fuse will result in no switched power to the gauge panel. Does the clock still work (BATT power)?
11-11-11 is offline
post #3 of 4 Old 05-26-2020, 05:48 PM
bruinjeeper
bruinjeeper's Avatar
These pink and black/white tracer wires?
They end up at the courtesy light harness under your dash. Unfamiliar with if this helps or not. Just read that and found it odd that I was dealing with those two wires then other day when I wired in a new LED strip courtesy light.
They end up on both sides...driver and passenger...
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #4 of 4 Old 06-01-2020, 10:44 AM Thread Starter
DRoness
No, the clock doesn't work either but there is a separate fuse in the fuse panel under dash that says clock, not sure if this was for another stock clock or something. Thanks
DRoness is offline
