1991 4.0 Loss of acceleration / power - Page 2 - JeepForum.com
post #16 of 21 Old 06-11-2012, 08:15 PM Thread Starter
MSUDawg
Originally Posted by Que89YJ
Cracked exhaust manifold or loose bolts on it. Bad temp sensor near tstat.
I changed temp sensor near Tatar this morning. No help. I did install it when the engine was hot and Haynes says I should hav let it sit a few hours before changing it (not sure if that maters)
MSUDawg is offline
post #17 of 21 Old 06-12-2012, 08:57 AM Thread Starter
MSUDawg
SOLVED!!!
My Mechanic, that charged me $135 for a fuel pressure test and new distributor cap / rotor (which I will never go back to) was wrong about the Catalytic Converter It was bad! So I replaced it and I have POWER AGAIN!
So you were right and my idiot mechanic was wrong! Thanks!
MSUDawg is offline
post #18 of 21 Old 06-12-2012, 09:18 AM
pasinbuy
To funny! I read your whole thread and when I reached the end I was going to tell you how to check your cat because the problem still sounded like the cat.
Makes me wonder how the mechanic thought the cat was fine. Maybe he looked at it, and then seeing that it looked OK, without testing gave it a OK. Lazy @ss mechanic.
Glad you found your problem.
pasinbuy is offline
post #19 of 21 Old 06-12-2012, 09:36 AM
Que89YJ
Me too Paisinbuy. I thought it was the cat. I wonder how the mechanic that said it was ok "tested" it.
Que89YJ is offline
post #20 of 21 Old 06-12-2012, 09:49 AM
pasinbuy
From the sounds of it. He looked at it, saw the outside of the cat looked ok and passed it.
pasinbuy is offline
post #21 of 21 Old 06-12-2012, 09:58 AM Thread Starter
MSUDawg
His idea was, if it didn't smell and it wasn't glowing red hot, it was fine.
I hope others learn from my Gullibility!!
MSUDawg is offline
1991 yj , loss of power
Massive power loss during acceleration. liveatibiza YJ Wrangler Technical Forum 14 06-14-2012 09:45 AM
loss of power under acceleration YJFreak YJ Wrangler Technical Forum 16 04-01-2011 11:37 PM
loss of power uphill/acceleration cryptostorm TJ Wrangler Technical Forum 10 08-10-2010 10:14 AM
Loss of power during acceleration SnatchBlock TJ Wrangler Technical Forum 5 06-15-2010 08:21 PM
Power/acceleration loss, especially uphill stripesthree YJ Wrangler Technical Forum 3 05-08-2010 11:26 AM
