1989 YJ 2.5L Valve Cover swap - JeepForum.com
post #1 of 5 Old 07-15-2020, 05:58 PM Thread Starter
Cfsmollen
So I need some help. I recently put an aluminum valve cover finally replacing the leaking plastic one. The installation went great but I have developed a vacuum leak. I am wondering if it has to do with how I have the PCV hose's set up. It is different than the old valve cover.
I hooked the front hose to the front of the intake manifold and the back hose to back of the intake manifold.
Can anyone help?
Cfsmollen is offline
post #2 of 5 Old 07-16-2020, 06:26 AM
fishadventure
fishadventure's Avatar
Iirc one goes from the air cleaner to the rocker cover, the valve goes in the cover to manifold. Something like that. Both to manifold sounds incorrect and I don’t think that will function right.
[size=3]Shackles & D-rings are different things.
Cranking IS turning over
fishadventure is offline
post #3 of 5 Old 07-16-2020, 04:42 PM
chesterm64
Rear hose goes to the air cleaner.
See this post for pictures https://www.jeepforum.com/forum/f12/...cover-4386637/
Mine looks like post #12 in that link. I removed the orifice fitting that came with the aluminum valve cover and put the original PCV valve inline.
chesterm64 is offline
post #4 of 5 Old 07-17-2020, 05:40 AM
bruinjeeper
bruinjeeper's Avatar
Yep.
Rear to air cleaner.
Front to driver side manifold port.
~YJOTM MAY '16, JULY '19~
bruinjeeper is online now
post #5 of 5 Old 07-17-2020, 08:12 PM
cas6969
cas6969's Avatar
I recently did the same and caused massive vacuum leaks. None of them from anything I touched intentionally though. Just disturbing the 32 year old hoses removing the rear passengers side bolt and bracketry caused 3 or 4 hoses back there (where the rubber transitions to metal) to come apart.
cas6969 is offline
