1987 rear vibration - JeepForum.com
 2Likes
post #1 of 42 Old 06-01-2019, 01:28 PM Thread Starter
Thumbs27
1987 rear vibration
Hi i am new to this site. I have a 1987 jeep wrangler yj tht has been converted to the 4.0l with a 42re automatic. The rear end has had the leaf spring perches rewelded on. The pinion angle seem to high, an whn u take off it shakes. But goes away aftwr a few seconds. This only happens on take of
Thumbs27 is offline
post #2 of 42 Old 06-01-2019, 01:37 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Post quality pics from different angles/views
Joe Dillard is offline
post #3 of 42 Old 06-03-2019, 12:37 PM
wishyouwereher
wishyouwereher's Avatar
If pinion angle is to high the ears on the driveshaft can hit the pinion on take off because the axle rolls back when tourer is applied. Check for a loose u-joint, it my have bent the u-joint straps that hold it to the pinion. Replace those with u-bolts, they are way stronger.
wishyouwereher is offline
post #4 of 42 Old 06-03-2019, 01:31 PM
Siva283
Siva283's Avatar
I am with Joe post pics. It could be alot more than a bad pinion angle as well. Could be the clutch also
Ask me how I know...
Siva283 is offline
post #5 of 42 Old 06-04-2019, 09:07 AM Thread Starter
Thumbs27
So i knw it cant be the clutch because it is an automatic. It has ubolt stay straps on it. As i add different degree shimes to it it makes it better. The people tht started building this jeep cut the original trans crossmember apart an rewelded it back together so im wondering if tht is part of the problem.
Thumbs27 is offline
post #6 of 42 Old 06-04-2019, 12:34 PM
Siva283
Siva283's Avatar
Instead of expecting us to telepathically see your jeep through your mind why dont you go ahead and take some pics and post them so you can get the help your asking for. I dont believe most of us have mastered seeing stuff using anothers eyes.
Awesome likes this.
Siva283 is offline
post #7 of 42 Old 06-05-2019, 09:02 AM Thread Starter
Thumbs27
Sorry have been so busy at work here is the only pic tht i have right now will get more soon
Thumbs27 is offline
post #8 of 42 Old 06-05-2019, 09:28 AM
Siva283
Siva283's Avatar
You mean you dont see the problem there? First your driveshaft is like 2 inches than resting angles are wrong any suspension travel at all takes you beyond what the u-joints can compensate for. There is everything wrong there. I dont know if an SYE would get you enough driveshaft but you definitly need one. I am also assuming that almost non existant driveshaft isnt balanced as I cant believe an driveshaft shoop would even entertain the idea of making a driveshaft that small.
I am starting to question if this is a troll post
Siva283 is offline
post #9 of 42 Old 06-05-2019, 09:39 AM
hofferwood
hofferwood's Avatar
Was downside up
If it aint broke---fix it till it is
hofferwood is offline
post #10 of 42 Old 06-05-2019, 09:46 AM
Siva283
Siva283's Avatar
Doesnt change the face that everything is wrong, Literally.
The driveshaft is waaaaay to short and I am sure unbalanced. The pinion angle is set up like its got an SYE and double cardon drive shaft. If the pinion was set right the u-joint angles would be way to severe. You at a minimum need an SYE and new driveshaft and probably a stretch too to get enough length on the driveshaft. I see of no way you can make that set up work as is
Siva283 is offline
post #11 of 42 Old 06-05-2019, 09:48 AM
Siva283
Siva283's Avatar
Oh and whomever made that monstrousity of a driveshaft phased the u-joints wrong when the welded it back up.
Siva283 is offline
post #12 of 42 Old 06-06-2019, 08:56 AM
wishyouwereher
Agreed
post #13 of 42 Old 06-06-2019, 09:05 AM Thread Starter
Thumbs27
The drive shaft is 6 1/2 inches long there is still 2 inches of in travel on the slip yok. As i add degree shimes to it turning the pinion down the shake has gotten better. An no this is not a troll post. This jeep was someones project. It has a 42rh automaticin it tht is why the drive shaft is so short
Thumbs27 is offline
post #14 of 42 Old 06-06-2019, 09:14 AM
222Doc
222Doc's Avatar
good god. could almost hard mount that rear to the trans lol......hard to be worse then this and think its close? Fc me.
yea a CD joint would take up about the space he has now and room for a spline joint. Might want to call someone like TW and ask whats the shortest shaft they could build, then move the rear so you have at least that much. You can gain some with a short SYE, not all that much though.
222Doc is offline
post #15 of 42 Old 06-06-2019, 09:19 AM Thread Starter
Thumbs27
All i am looking to do is get ride of the shake when i first take off. This jeep is not an off road jeep. As i turn the pinion angle down the shake is not as bad. It kinda going away. So am i on the right track or not.
Thumbs27 is offline
