1.5-3" Lift - JeepForum.com
 2Likes
  • 1 Post By bestos
  • 1 Post By AmmitOsiris
post #1 of 11 Old 03-18-2016, 12:08 AM Thread Starter
90yjkrawler
1.5-3" Lift
With putting this SBC350 in my already saggy springs are no w completely flat. I figure if I'm replacing springs I might as well lift it. Will I have to get stronger springs up front? Not sure what lift will hold the extra weight going from 4 to 8 cyls. I don't want to go very high, I just want something to clear 31s or so. No winch or heavy bumpers and a soft top.
Until They All Come Home!
90yjkrawler is offline
post #2 of 11 Old 03-18-2016, 08:09 AM
StanF
2" or 2.5" lift would be good for 31s
Zone 2" lift for budget.
Rubicon Express or OME 2.5" lift, if you can afford it. I have RE 2.5" springs, and highly recommend them. OME also gets very high recommendations.
StanF is offline
post #3 of 11 Old 03-18-2016, 09:08 AM
bestos
OME HEAVY duty front and rear springs with OME shocks!!!!!!!!!!!!!!! that is what you WANT!
Chrisnvegas likes this.
1995 YJ - 33" BFG KM2 - 4.88 w/ Aussie front locker. 2.5" OME. 5/8" shackle. 1" JKS body.
1991 YJ - 4.0 - Stock and banged up and recent purchase
bestos is offline
post #4 of 11 Old 03-18-2016, 09:33 AM
bruinjeeper
Moderation in Moderation
bruinjeeper's Avatar
OME C036r's
~YJOTM MAY '16, JULY '19~
bruinjeeper is offline
post #5 of 11 Old 03-19-2016, 11:07 PM
Jeepfreak81
Jeepfreak81's Avatar
The SBC is only marginally heavier than the 4 cylinder. I did this swap years ago on stock springs, then moved to 2" BDS springs.
I would buy what you want and not worry about it. My BDS springs are 13+ years old now and are still fine.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #6 of 11 Old 03-22-2016, 10:59 AM Thread Starter
90yjkrawler
I think for the price difference I'm going to go with a Rustys 4in kit. Seems to be the most complete and I can't find anything bad about it. I'll just save up a bit more and get 33's.
post #7 of 11 Old 03-23-2016, 05:53 AM
AmmitOsiris
AmmitOsiris's Avatar
just go bus or ome, you'll thank yourself in the long run.
AmmitOsiris is offline
post #8 of 11 Old 03-27-2016, 11:05 PM Thread Starter
90yjkrawler
After a few replies, I think I'm going to piece together a lift kit. Just using Quadratec alone I was able to price everything I need besides hardware for $1075. That includes shocks plus I was able to fit in a shackle reversal kit and new 3/4 lift greaseable boom shackles (full set), RE 4" lift springs and RE quick disconnect sway bar links, and a couple other things for that price. Might save more if I shop around depending on shipping.
post #9 of 11 Old 03-28-2016, 02:07 PM
Sprungover
Sprungover's Avatar
I'm down the road from Rustys. I thought about the same, but I cant find anyone who has ever run their YJ lift on any forum or in person. The spring rate is a little softer than the OME 36r
1989 YJ, 1977 CJ-7
Sprungover is offline
post #10 of 11 Old 03-29-2016, 08:26 AM
Jeepfreak81
Plan on $100+ for hardware. U-bolts alone are around $10-$15 each. Many bolts will also likely have to be cut.
post #11 of 11 Old 03-29-2016, 09:58 AM
Sprungover
Sprungover's Avatar
luuca did the work for what you'll need to piece it together and I've found they have the cheapest price.
https://www.jeepforum.com/forum/f12/l.../#post33215922
1989 YJ, 1977 CJ-7
