XJ "Dieseling" after new Sensors - JeepForum.com
 1Likes
  • 1 Post By cruiser54
post #1 of 9 Old 01-20-2020, 10:58 AM Thread Starter
legendslayer
legendslayer's Avatar
I also have a 93 XJ that's my daily, i was getting poor milage so i tuned up the engine new champion spark plugs, wires, distributor cap, air filter and sensors TPS, MAP, IAC and cleaned up the throttle body abit, but the engines been running really rich since.
alot of the parts were mid range ordered off rockauto, never economy brand but never premium either
the tail pipe turned black at the tip and a i experience i extra 4 - 5 engine cranks after killing the ignition when the car is warmed up
sometimes the car idles at 1500 rpm in park
Kinda lazy let this issue slide for awhile took me like a month to install a ball joint on my other jeep haha
i still have all my old sensors to try to switch one out for comparison
not really sure how to tell which ones bad or "under performing" however
legendslayer is offline
post #2 of 9 Old 01-20-2020, 12:50 PM
Fourspeedman
Fourspeedman's Avatar
The rule-of-thumb in mechanics-world is to put back whatever you changed until the offending part is exposed. But I would suspect the MAP as it is basically a vacuum gauge telling the computer how much of a load is on the engine.
Mark in Queens- Home of Spiderman and the Ramones
Fourspeedman is online now
post #3 of 9 Old 01-21-2020, 05:25 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I'm gonna bet the tube/hose from MAP to intake manifold has a leak from being disturbed.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 9 Old 01-23-2020, 06:28 PM
car6car
it should have engine code.
O2 sensors usually last about 100k miles.
04 Grand (dead)
car6car is offline
post #5 of 9 Old 01-24-2020, 09:31 AM Thread Starter
legendslayer
I don't have a check engine light on and its a 93, So OBD1 not 2, They don't really make consumer OBD1 Live data code readers.
not to mention the header, exhaust and sensors have less then 10k miles threw them
taped all the hoes up, made sure they were all attached, not seeing any immediate differences
2 people mentioned MAP, maybe mines a lemon, the one in there right now is a Spectra Premium part ID MP102
Would a poorly sealed exhaust manifold cause any of these issues?
https://www.rockauto.com/en/moreinfo...%2BPPsdyoCi3ob
Was like 30 bucks, maybe ill try a third one?
post #6 of 9 Old 01-24-2020, 10:32 AM
jtec
jtec's Avatar
2014 JK Wrangler
yes an exhaust leak would skew o2 sensor readings possibly causing them to see a lean condition, resulting in eng adding fuel.
speaking of fuel - ck fuel pressure with a gauge?
jtec is online now
post #7 of 9 Old 01-24-2020, 03:31 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Taped up the hoses?
2oldjeeps likes this.
post #8 of 9 Old 01-24-2020, 10:32 PM Thread Starter
legendslayer
Now that you mention, i did put a new Wix fuel filter with the tune and sometime later down the line the Fuel Pump Ballast Resistor physically broke in the engine bay, the same ones in there still, pretty sure its just wired together at the moment and not bypassed. engine doesn't stay on with out it. Talking it out with you, i realize this could be a culprit. I'll have to go pick up a gauge to check the fuel rail tho.
i installed the exhaust manifold months before these issues arose and have had inspections since then with no mentions of a leak, so for now ill rule out the exhaust leak but will consider it heavily.
Taped up the hoses?
Only temporarily but i wrapped some thermotek automotive tape around most of the vacuum lines and tubes in a poor mans attempt to seal any leaks.
APPRECIATE ALL THE ADVICE SO FAR GUYS THANK YOU ALL
post #9 of 9 Old 01-25-2020, 07:15 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
With it idling, spray some carb cleaner around the vacuum lines. You'll find it.
