Xj battery - JeepForum.com
post #1 of 8 Old 01-25-2017, 04:24 PM Thread Starter
Xjlover24
Xj battery
What size of battery should I run in my 88 Cherokee? The one in it is toast
Xjlover24 is offline
post #2 of 8 Old 01-25-2017, 04:27 PM
desbennett004
Measure the physical size, find one that will fit in the same space with the highest Cold Cranking Amps (CCA) you can find. My battery is 850cca.
Sent from my SM-N900W8 using Tapatalk
desbennett004 is offline
post #3 of 8 Old 01-25-2017, 04:49 PM
SemperFiGuy
1980 CJ5
Go to any auto store site, put in your vehicle information, and waalaa, magic. Or even better magic is look at what your current battery says.
Sent from my SM-T230NU using Tapatalk
SemperFiGuy is offline
post #4 of 8 Old 01-25-2017, 05:22 PM Thread Starter
Xjlover24
The battery's so old the labels are just white now
post #5 of 8 Old 01-25-2017, 05:23 PM
SemperFiGuy
1980 CJ5
Ahhhh, go to the store site then, Walmart has a thing as well, in store,
post #6 of 8 Old 02-03-2017, 09:56 PM
GrumpyViking
My 01 XJ takes 800CCA according to the book, may go a bit bigger if it draws a lot while using my XRC 9,500Lb winch.
GrumpyViking is offline
post #7 of 8 Old 02-05-2017, 12:50 AM
Investinwaffles
I think you can fit a type-34 battery if you get a battery tray from a 97+ XJ
Don't quote me on that though, do some research as IIRC its a pretty common mod
Investinwaffles is offline
post #8 of 8 Old 02-05-2017, 10:38 AM
Tru2Chevy
Tru2Chevy's Avatar
1992 XJ Cherokee
IIRC, the earlier XJs came stock with a 58, 97-01s came with a 34 or 34/78.
- Justin
1992 Cherokee Laredo - mostly stock, DD. 300k miles and counting
2004 Grand Cherokee Laredo - 4.7, bone stock - Wife's DD
Tru2Chevy is offline
