xj airbag removal? - JeepForum.com
post #1 of 6 Old 07-01-2009, 11:36 AM Thread Starter
jeepinjames20
jeepinjames20's Avatar
xj airbag removal?
hello
I am posting for a friend so please forgive my profile information not giving you the correct vehicle to look at while deciding how to help.
My friend has a 95 XJ which only has a drivers side airbag. Now the trick of it is that he wants to remove the airbag for those off roading cases where if he hits a tree he doesn't want it to deploy. We also live in the great state of New Jersey to where if their is an airbag light he will not pass inspection.
Is their a way to disconnect the airbag or remove it completely but not have it throw a code that would hinder him from passing inspection.
all help is greatly appreciated.
thank you.
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
JEEPen James
Firefighters Jeep Club
Build...Run...Break...Repair...Repeat...
jeepinjames20 is offline
post #2 of 6 Old 07-01-2009, 11:53 AM
MJR
MJR's Avatar
1988
The air bag in 95-96 are purely mechanical no electronics what so ever so there is no air bag light. I don't know of anyone having a problem with air bags deploying off road unless it was warranted. The is anothr post in here from just a day ago that describes the procedure. You don't have to remove it just disarm it with the screw on top of the steering wheel.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #3 of 6 Old 07-01-2009, 11:56 AM
danw77
danw77's Avatar
1994 ZJ
just pop the plug on top of the steering column and back the screw out (iirc it's a torx). make sure to stand outside the jeep and look through the windshield in case it goes off.
82 CJ7: 4.2l, SR4
94 ZJ: 5.2l, 46RH
90 YJ: 2.5l, AX5
danw77 is offline
post #4 of 6 Old 07-01-2009, 11:58 AM
MJR
MJR's Avatar
1988
https://www.jeepforum.com/forum/showthread.php?t=808214
Its a 5/16" or mm bolt.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
post #5 of 6 Old 07-01-2009, 12:31 PM
That1guy
That1guy's Avatar
2007 WK
I would leave it in there unless its a trail rig. It's very rare to deploy under normal off road stuff.
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline
post #6 of 6 Old 07-01-2009, 12:42 PM
danw77
danw77's Avatar
1994 ZJ
just don't do this: http://www.youtube.com/watch?v=iH72-7HBarM
82 CJ7: 4.2l, SR4
94 ZJ: 5.2l, 46RH
90 YJ: 2.5l, AX5
danw77 is offline
Swapping airbag wheel to early non airbag wheel, can it be done? LobstahJeep XJ Cherokee Technical Forum 7 02-02-2009 03:09 PM
Airbag/SRS XJKyle1389 XJ/MJ Cherokee Non-Technical Forum 0 10-11-2008 05:06 PM
Airbag? skipo XJ/MJ Cherokee Non-Technical Forum 0 06-09-2008 03:00 PM
airbag removal?? Jamie Barkwell XJ Cherokee Technical Forum 7 12-07-2007 10:15 PM
Airbag? mbood82 XJ Cherokee Technical Forum 1 02-08-2005 09:14 AM
