LinkBack | Thread Tools |
Wondering How Guys Have Handled Removing Old Battery Cables For The Upgrade Mod
When you guys have been upgrading your battery cables wondering how you have been removing the old cables?
Jeep in question is an '00 XJ.
Been wondering if you could cut off an end and pull it out of the loom leaving what you are not replacing intact.
Then just run the new cables separate from the original harness.
Thinking it is wrapped to tight and they will not pull through.
Maybe you guys are just cutting them off as close the loom as possible leaving what is left in there.
Then just routing the new cables separate.
Maybe you are going through all the trouble of unwrapping the harness and then rewrapping it with the new cables inside.
Obviously the goal is to do a clean looking install.
At least as clean as possible.
Sponsored Links | |||
Originally Posted by Ralph77
View Post
I can't remember if I used electrical tape or the cloth type friction tape or a combo of them. I think I wrapped the wires together, then put on the electrical loom. Then wrapped tape around the loom every so many inches, say 6.
I did make my own cables. I followed one of the write-ups. Possibly I used marine grade wire. Also, used one of the Chinese made wire crimpers. Once I figured out what crimping blocks to use, it worked OK.
When I did mine I had to re-use the bracket at the starter by bending it open and hoping not to break it. That went well. Then had to do the same attaching the 4awg cable to the pdc. Other than that, my wiring isn't laid out anywhere near stock.
D3<!L!>3D
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Posting Rules | |
