Wiring up LEDs for the JCR quarter guards with integrated tail lights - JeepForum.com
post #1 of 17 Old 11-18-2009, 06:22 PM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
Hey guys,
I just bought the quarter panel guards from JCR and they should be here at the end of next week. I am hoping to have these mounted and wired up in one afternoon so i can make it to the Badlands Nov. 28th. But i have some questions about the wiring of the lights.
I ordered a 6" oval (tail/stop/turn) LED, 2.5" round Reverse light, and a 2" red round turn signal for the side of the panel. I also bought all of the "pigtails" to connect to the back of the LEDs
I have never messed around with LEDs before, so will someone explain to me the best way to wire these up? I heard something about needing an electronic flasher but in all the install writeups ive seen for the THOR guards i have never seen a use of a flasher, nor have i seen anyone really go into great detail about the wiring.
Can someone please explain to me what i need?
-Brendan
for those of you who havent seen the product that i'm talking about
Cherokee Rear Upper Quarter Panel Guards (97 up): JcrOffroad, Inc.
2014 Jeep Wrangler Sport S
3.6L V6 - Manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline
post #2 of 17 Old 11-18-2009, 06:36 PM
cornbrizzle
1992 XJ Cherokee
https://www.jeepforum.com/forum/f9/le...ng-fix-887976/
This might help?
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline
post #3 of 17 Old 11-18-2009, 08:12 PM
XJChris98
You'll need and electric flasher to get the lights to flash right (located under the drivers side of the dash, along the outside "wall"). I think they're ~18$ and can be found at any autoparts store (napa, autozone, advance, etc). If your having trouble finding it, just turn the flasher on and listen for it.
To get the rear lights wired up and working (correctly), you'll need one of these:
Tow Ready Website - 119130
From my understanding, this is the ONLY unit that will work on the XJ's. I dont know why, but when I did my tailights thats what I used and didnt have any issues. CHECK EBAY for this item, I picked one up on there brand new for $15.
Refer to this writeup: wiring up LED STOP TURN TAIL For light boxes Thor guards (w/pics) - NAXJA Forums -::- North American XJ Association
XJChris98 is offline
post #4 of 17 Old 11-18-2009, 10:08 PM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
i picked up the tow ready setup but im having trouble locating a electric flasher online
3.6L V6 - Manual
bmyohn is offline
post #5 of 17 Old 11-18-2009, 10:51 PM
XJChris98
post #6 of 17 Old 11-18-2009, 11:00 PM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
awesome thanks chris i was searching for the wrong terms. so by doing what you posted in that NAXJA writeup as well as the electronic flasher i should be set to wire these up. and my front turn signals should still work just fine?
3.6L V6 - Manual
bmyohn is offline
post #7 of 17 Old 11-18-2009, 11:19 PM
XJChris98
If you follow hammered's writeup, it should work perfect. The whole towready box thing may seem confusing, but it helps to just look at his actual pictures of which wire goes to where. Thats what I did and didnt have any problems.
I tied my side markers into the constant 12v source, so they would be "on" when the parking/headlights were on, but didnt "flash" with the turnsignals.
Good luck!
post #8 of 17 Old 11-19-2009, 08:23 AM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
sounds good, i will do what hammered did and if it does do the "quick flash" i will run to NAPA and pick up that electronic flasher
3.6L V6 - Manual
bmyohn is offline
post #9 of 17 Old 11-19-2009, 12:13 PM
Haleyes
There's really nothing to it. I think you're making it harder than it really is and you've not even started yet!
For those that haven't seen JCR's new 1/4 guards:
97 and up is also available.
JcrOffroad, Inc.
96' XJ, 33's and 4.88's
Haleyes is offline
post #10 of 17 Old 12-08-2009, 02:20 PM
Rural-Assault
Rural-Assault's Avatar
Good luck!
I just ordered the towready box today. I'd like to do the same thing you did with your side lights. How did you wire those in to come on with the running lights? I have the jcr taillight boxs.
XJ SPORT® 8" on 36's Geared,Locked & Caged
Rural-Assault is offline
post #11 of 17 Old 12-08-2009, 08:26 PM
srmitchell
Did you install them yet?
Can't wait to see em!
2004 Grand Cherokee Overland Project
2019 Compass Trailhawk DD
srmitchell is offline
post #12 of 17 Old 12-08-2009, 08:32 PM
XJChris98
I believe I just tied them into the parking light wire for the rear S/T/T lights. They dont "flash" when the rear ones flash though, just stay on constant when the parking/headlights are on.
If thats not it, just stick a multimeter on the wires and find one with constant 12v (even when the flashers are running). Since your using LED's they pull nearly no current so you shouldnt have any issues blowing fuses/etc.
post #13 of 17 Old 12-08-2009, 08:40 PM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
i have the drivers side done. the gap by the tail gate isnt what i hoped it would be. its about a half inch off. i think that i may have mounted the front about a 1/4" high in the front. so i have a much better idea of how to go about mounting the passenger side so there is little to no gap at the hatch
3.6L V6 - Manual
bmyohn is offline
post #14 of 17 Old 12-08-2009, 09:25 PM
josh94xj
1994 XJ Cherokee
JcrOffroad, Inc.
any one kno wat kind of rear bumber this is?
"Jeep. Go prepared."
Originally Posted by Teal2doorXJ View Post
i say screw it and just rawdog it!
Originally Posted by cherokeekid58 View Post
Selling your jeep is like selling your soul....
NEW JEEP PROJECT COMEING SOON!
josh94xj is offline
post #15 of 17 Old 12-08-2009, 09:26 PM Thread Starter
bmyohn
Youngin'
bmyohn's Avatar
that is a JCR Offroad bumper
http://www.jcroffroad.com/Merchant2/...egory_Code=XJB
3.6L V6 - Manual
bmyohn is offline
upper quarter guards reelrebel18 XJ Cherokee Technical Forum 4 01-22-2008 10:14 PM
Where can i find stone guards for tail lights!! jayandcourt XJ Cherokee Technical Forum 1 10-11-2007 04:50 PM
Rear Quarter Guards and Metal Lights - ** PICS ** LEAD_NOT_FOLLOW XJ Cherokee Technical Forum 26 04-14-2007 09:18 AM
LED tail lights, where to get the LEDs? HeavyMetal XJ Cherokee Technical Forum 23 08-31-2006 06:48 PM
Rear Quarter Guards LEAD_NOT_FOLLOW XJ Cherokee Technical Forum 6 12-02-2005 02:49 PM
