Winona won't start... - JeepForum.com
post #1 of 4 Old 03-31-2015, 07:33 PM Thread Starter
pullinoutisbad
1994 XJ Cherokee
On the way to work the other day she stalled for the first time ever started back up no prob in 5 min. 5 min later stalled again, same thing starts right back up. on the way back she stalled 4 times each time took at least 30 min until she turned over normally. 10 min drive turned into 2 hour drive/wait... made it home, thanks jesus!
next day she cranks but doesn't turn over. I didn't have fuel pressure in the rail, so I replaced the fuel pump. she starts right up 3 times in a row no prob! "fixed" by this time its kinda late so I don't drive her.
next day same thing cranks-wont turn over. fuel in rail. I did a spark test by myself, who knows if I did it right, anyway didn't see a spark so I replaced the coil. she starts up again no prob 4 times in a row. "FIXED" it was late again so I didn't drive.
same sh*t the next day if you can believe that. I replaced the CPS, same thing, starts a deceitful amount of times!(7) "fixed..."
yesterday, cranks wont turn over. until I wiggled the firewall cluster. again starts up this time 7 freaking times in a row!! "FIXED!!!" stalled coming home on the way back from autozone 3 times, wiggled the firewall cluster she'd start right up.
today, she cranks but wont turn the f*** over?!! no matter how much I finger blast that firewall cluster. I have fuel pressure after I crank it, fuses and relays seem to be good, i'll wait until dark to try a spark test again. My dad used to be a mechanic and owns/fixes jeeps but hes 6 hours away. He thinks its an electrical issue.
PLEASE HELP ME, any input helps. IDEAS??
pullinoutisbad is offline
post #2 of 4 Old 04-01-2015, 06:03 PM
Agony Wagon
Agony Wagon's Avatar
1995 XJ Cherokee
Maybe whatever you were jigglin on the firewall has been done jiggled apart.
Maybe your ground cable isn't grounding. Check to make sure that's good.
Maybe your NSS is bad. To test, you can jump the terminals in it.
Agony Wagon is offline
post #3 of 4 Old 04-01-2015, 08:13 PM Thread Starter
pullinoutisbad
1994 XJ Cherokee
welp now its not getting fuel to the rail...
it couldn't be that damn pump, I just replaced it.
what else could be the cause?
post #4 of 4 Old 04-02-2015, 03:42 AM
LJ Dave
When I replaced the fuel pump on my '88 XJ, it had a rubber hose that went from the pump to the bulk head fitting inside the tank . The first time I over tightened the hose clamp on that hose and found that because it is submerged in gas the hose gets very soft and gummy and the hose clamp cut through the hose after a few days causing me to loose fuel pressure as fuel was leaking out of the hose inside the tank. After a day or so the hose failed so bad that the Jeep wouldn't run. The second time I went into the tank to fix it, I left the clamps slightly too loose and the hose came off on one end. Not sure if they changed this design in later years but it was a real PITA to get right. I ended up using two hose clamps on the end that came off so I could get enough clamping force on the hose without splitting it.
Don't know if this is your issue, but it sounds like you may have to pull the new fuel pump out and see what 's going on inside the tank.
2005 Rubicon LJ 4.5 inches of lift, 35's
LJ Dave is offline
electrical , mystery , random stalling , stalling , wont start
