Window slipped - JeepForum.com
 1Likes
  • 1 Post By CJ7-Tim
post #1 of 3 Old 11-28-2019, 11:54 AM Thread Starter
ddraeg
ddraeg's Avatar
Window slipped
The passenger (RHD) or Driver's side (LHD) glass drops forward when opening, this makes it difficult to close.
There's a saying - 'if its snowing on me its snowing on someone else too'
I'm pretty sure someone on here has an answer.
Any ideas?
Thanks
ddraeg is offline
post #2 of 3 Old 11-28-2019, 12:28 PM
Ralph77
My first guess is that the window is coming loose from the regulator.
Ralph77 is online now
post #3 of 3 Old 11-28-2019, 01:24 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Remove the door trim panel. Make sure the rubber U channel the glass slides in is not out of the metal guide channel, or kinked in any way. Move the glass until you see the bolt that holds it to the regulator. Tip the glass gently the opposite way it is falling down, and snug the bolt very gently 1/4 turn. Run the glass up/down a few times to see if that helps. Consider rubbing some candle wax, not grease or any kind of lube, in the rubber channel just at the point it sticks or tips. In extreme cases you may have to remove the glass, and bend the metal guide channel slightly in.
ddraeg likes this.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
“The powers delegated by the proposed Constitution to the federal government are few and defined. Those which are to remain
in the State governments are numerous and indefinite.”
- James Madison
CJ7-Tim is offline
