Will this remote starter work? - JeepForum.com
post #1 of 4 Old 08-11-2009, 03:08 PM Thread Starter
Spokes
Spokes's Avatar
i found this on CL. i was wondering if it will work on my 01 xj 4.0? i no it says its for a liiberty but is there rly that big of a diference? lol i want remote start for those 5am hockey practices when its 5degrees out lol thanks!
http://newjersey.craigslist.org/pts/1274473671.html
Red 00 XJ lifted
Build -->
Blue 00 XJ Hella stock
"Lima bean" 91 XJ 5spd
Spokes is offline
post #2 of 4 Old 08-11-2009, 03:21 PM
Mickey_D
Mickey_D's Avatar
I don't think any of the remote start companies make their systems vehicle specific. They have add-on wiring harnesses to do that, but the base system is identical whether it's going in a Dodge Neon, a Chevy Silverado, a Jaguar XJ6 or a an XJ Jeep. The only difference in the models themselves is the features they offer.
Check the manufacturer's website see if they make the plug in harness for that model to go in an XJ. I know that Bulldog Security does that. They call them "T Harnesses" because of the connection they make. You unplug the ignition switch harness and the T harness plugs in between the stock connectors.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #3 of 4 Old 08-11-2009, 04:41 PM
GunnerT23
Really. if you have a transponder key. your much better off going to a shop. if its a basic key that you can get replaced at a local hardware store. go ahead and try. I did a viper on mine. works excellent!
GunnerT23 is offline
post #4 of 4 Old 08-11-2009, 07:24 PM
lostissues
1987 MJ Comanche
that remote start should work fine for you 01 XJ. if you do have a transponder key you will need a DEI 556UW but I don't believe you do. you hook it up and put the extra key in it. you should also need a DEI 451M for your door locks if you plan on hooking them up. the negative signal provided for the lock and unlock wire are not enough to trigger the Cherokees door lock actuators.
lostissues is offline
Remote starter B_carney XJ Cherokee Technical Forum 0 03-21-2009 06:00 PM
Cherokee Remote Starter Remote jeepin71 XJ Cherokee Technical Forum 5 03-23-2008 06:46 PM
Remote Starter shelby_Extreme XJ Cherokee Technical Forum 2 10-24-2006 06:32 AM
Remote Starter Aquit45 XJ Cherokee Technical Forum 8 03-01-2005 01:47 PM
remote starter xjinthemud XJ Cherokee Technical Forum 5 11-05-2003 09:03 PM
