Will not down shift - JeepForum.com
post #1 of 18 Old 02-19-2020, 01:21 PM Thread Starter
Hamid
Hamid's Avatar
Will not down shift
Dear all:
I was climbing a hill 2 days ago, noticed my 2000 XJ Classic A/T ( AW4 ) will not down shift from 3 to 2 when pressing on gas pedal, anyone knows what is the cause, I appreciate your help.
2000 Jeep Cherokee Classic. Built for export
432K Kilos.
Hamid is offline
post #2 of 18 Old 02-19-2020, 02:47 PM
jtec
jtec's Avatar
2014 JK Wrangler
might want to start with a scan for trans codes.
jtec is offline
post #3 of 18 Old 02-19-2020, 03:52 PM
Pinoy59
1997 XJ Cherokee
Maybe check the shiftdown cable, it goes from the throttle to the transmission.
Sent from my SM-G975U using Tapatalk
NP242/skidplates/RC4.5"LA kit/33x12.5mudclaws/15x10rim/sliders&flares/trussed-locked8.8/winchbumper
Pinoy59 is offline
post #4 of 18 Old 02-19-2020, 03:57 PM
radventurer
radventurer's Avatar
TPS would be another check... 50$ at AZ. How’s the trans fluid level/ smell?
Sent from my iPhone using Tapatalk
Follow my
radventurer is offline
post #5 of 18 Old 02-20-2020, 05:29 AM Thread Starter
Hamid
Hamid's Avatar
Thank you for your replies, good ideas
I don't have a way to read trans code.
I will check oil level and smell.
432K Kilos.
Hamid is offline
post #6 of 18 Old 02-20-2020, 06:20 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That is NOT a kickdown cable. It's a Throttle Valve cable that increases line pressure inside the trans when the throttle is opened. the shifts are controlled electronically.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #7 of 18 Old 02-20-2020, 06:22 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The trans is supposed to be drained and refilled every 30,000 miles. Ever done it?
Just remove the plug, drain it, reinstall theplug and fill lit. Takes about a gallon. Use only Dex/Merc 3 fluid. Available everywhere.
post #8 of 18 Old 02-20-2020, 06:26 AM
jtec
jtec's Avatar
2014 JK Wrangler
lets start - does the CEL come on @3seconds then go out at every start?
Did you try key on off trick to get codes?
you can get free scans at many auto part stores....
You had not thought to check fluid until above suggestion?
jtec is offline
post #9 of 18 Old 02-20-2020, 06:29 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Simple and basic are good things.
First thing I do on a "new to me" vehicle is check all the fluid levels and condition......
post #10 of 18 Old 02-24-2020, 09:36 PM Thread Starter
Hamid
Hamid's Avatar
I posted 2 replies, don't see them on the thread, so I am posting again,
I changed Tranny oil, it was more like brown, smells burned, soft dirt was accumulated on the 2 magnets inside the pan.
I used Mopar ATF4, hope that is recommended. I will drive it this morning and post the results.
432K Kilos.
Hamid is offline
post #11 of 18 Old 02-25-2020, 05:10 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Unfortunately, you used the wrong fluid.
Use Dex/Merc.
post #12 of 18 Old 02-25-2020, 06:16 AM
jtec
jtec's Avatar
2014 JK Wrangler
AGREE with above.
AND he advised you four days ago what fluid to use!!
from owners manual!!
Mopar Dexron IIE/Mercon is the recommended fluid for the AW-4 automatic transmissions.
jtec is offline
post #13 of 18 Old 02-25-2020, 06:43 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
AGREE with above.
Like this:
post #14 of 18 Old 02-25-2020, 09:50 AM Thread Starter
Hamid
Hamid's Avatar
So I made a bobo, sorry not to pay attention to your note. I will replace it tomorrow, do I have to flush or just put the new oil
What will the wrong oil have an effect on the tranny on long term basis?.
432K Kilos.
Hamid is offline
post #15 of 18 Old 02-25-2020, 02:22 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Long term at this point, you're fine. drain and refill 2 times, driving the Jeep for a few days in between.
