where to relocate the vacuum canister - JeepForum.com
post #1 of 14 Old 04-17-2004, 06:32 PM Thread Starter
hman333
hman333's Avatar
hey where should i put it, i have looked around on the forum but there are no pics or how-tos on doing it.
thanks harris
1992 Cherokee Laredo 4x4
Custon Hidden 3-link on 39.5" Iroks
hman333 is offline
post #2 of 14 Old 04-17-2004, 06:50 PM
cfkingfish
Guest
What is wrong with where it is now? I dont see the problem with it being there, but if you want to relocate it, try near the air filter if you convert to a cone setup - this way it will be closer to all of the tubes it feeds.
-Christian
cfkingfish is offline
post #3 of 14 Old 04-18-2004, 02:52 AM
EricsXJ
The Post man
EricsXJ's Avatar
How about here? It was very easy...
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #4 of 14 Old 04-18-2004, 07:39 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
I had mine where Eric has his but shortly after knocked it off and lost it. This ended up in the vacuum sucking up water and Fing my MAP sensor. Anyway, I know have it under the hood right next to the fuse block. All you do is pull the vaccum hose back, coil it up and put the canister where ever you want.
Matt
MSHarnett is offline
post #5 of 14 Old 04-18-2004, 09:31 AM
EnderUSAF
Guest
I have mine in the engine compartment near the fuse box... hell I don't even have it attatched to anything. It's just kind of sitting on top of stuff in there. It isn't going anywhere though.
EnderUSAF is offline
post #6 of 14 Old 04-18-2004, 04:06 PM
JEEPZZ
JEEPZZ's Avatar
I've got mine where Eric'z iz.
I also used a few zip tiez in there just in case the screwz come loose I won't loose the canister.
[FONT=Trebuchet MS][size=1]97XJ RENEGADE
JEEPZZ is offline
post #7 of 14 Old 07-06-2004, 12:03 PM
mississippi_xj
mississippi_xj's Avatar
what are those little french horn looking devices? can they be mooved or take off?
scotty
-scotty
Shopping for a WJ to replace my DD Land Rover, Former TJ/YJ/XJ/WRX Builder...
mississippi_xj is offline
post #8 of 14 Old 07-06-2004, 12:05 PM
Blue XJ
Blue XJ's Avatar
1988 MJ Comanche
Those are the horns, there is one on each side. I owuldn't take them off, but you could move them to wherever.
Blue XJ is offline
post #9 of 14 Old 07-06-2004, 12:24 PM
Jason, aka: Jeepin.com
Vendor
Jason, aka: Jeepin.com's Avatar
1995 XJ Cherokee
The pre-'97 XJ's have an oblong vac-canister that won't really fit on the support brace under the turn signal. I relocated mine to behind the nose panel, just to the side of the steering box. Fits great in there and used existing holes. I used some 1/4" ID fuel line to extend the vaccuum tube over there. I keep meaning to take some pics for a quick write-up for Jeepin.com but haven't gotten around to it yet.
Jason West -
'16 JKUR Hard Rock, RE/Synergy 3.5", 37" GY MTR/Ks
'95 XJ, RE 5.5", 35" MT/Rs, D30 w/hubs & ARB, D44 w/Detroit, 4.56s, C4x4 bumpers, etc, etc.
'00 TJ, SOLD, wife's, RE 4.5" long-arm, 35" MT/Rs, D30+OX, D44+ARB, 4.88s, full cage, winch, C4x4 & Jeeperman bumpers, etc, etc.
Jason, aka: Jeepin.com is offline
post #10 of 14 Old 07-06-2004, 01:16 PM
mississippi_xj
wo..... i had no idea that they were really the hornes. that is pretty cool.... maybe i should moove them up to the roof rack
scotty
-scotty
post #11 of 14 Old 07-06-2004, 01:38 PM
DXJ
hman333 - My first question is "Why do you want to move it?" That might have something to do with where is the best place.
I got a BPI winch bumper and had to put mine somewhere. Their directions suggest where EricsXJ put his but when I trimmed my fenders, those support braces had to go. I ended up drilling two holes in my new bumper and mounting it on my new bumper exactly where it was on my old bumper. I thought about under the hood but that seems to be filling up.
95 XJ
2dr 4lt Auto
35x12.5 MTs and some other stuff
DXJ is offline
post #12 of 14 Old 07-06-2004, 02:32 PM
Sterling90XJ
Guest
Those who have relocated theirs to beside the fuse box... please post up a pic or two, and how you disconnected and re-routed the hoses. I'll be getting a ProtoFab tube winch bumper soon, and would like to not have mine exposed in the current stock location.
Sterling90XJ is offline
post #13 of 14 Old 04-05-2020, 07:15 PM
radventurer
radventurer's Avatar
I literally just nested it next to the fuse box... curled the tube and it just sits in an open space. No zip ties... itís pretty jenky, but no issues after several wheeling trips and a drive across country from Cleveland to Colorado.
Sent from my iPhone using Tapatalk
Follow my
radventurer is offline
post #14 of 14 Old 04-06-2020, 06:46 PM
grwgoldpro
grwgoldpro's Avatar
I strapped mine to the right hand fender brace behind the original bumper with tie wraps and one existing screw hole when I installed my aftermarket bumper. Mine is the ball type not the football shape. Lots of miles on dirt roads and no problem.
Gary
grwgoldpro is offline
where are the vacuum lines to the front vacuum canister??? Elliottm2333 XJ Cherokee Technical Forum 3 03-13-2007 09:26 PM
Where to go with vacuum canister? Wisbar XJ Cherokee Technical Forum 13 07-21-2005 06:16 AM
Vacuum Canister & Vacuum Diagram saxj XJ Cherokee Technical Forum 9 05-06-2005 02:08 AM
Relocate Horns and Vacuum Canister IntrepidXJ XJ Cherokee Technical Forum 2 12-22-2003 12:04 PM
Vacuum Canister on 90 XJ VR6 XJ Cherokee Technical Forum 6 12-07-2003 08:23 AM
