What is the best radiator upgrade for a 98 4L? - Page 2 - JeepForum.com
post #16 of 18 Old 01-08-2015, 03:50 PM
skyway0018746
Originally Posted by muddflow View Post
Some of the less expensive heavy duty all aluminum radiators, have had problems with quality control. I remember reading one person went through three returns all of which failed and had leaks.
Even the more expensive all aluminum radiators have quality issues. I've been through 3 flex-a-lite radiators . pure junk .
Make sure you get one with a warranty longer then a year ....
7" long arm lift, HNT sye , herculined inside, bush wacker fender flares now geared and locked !!!
62 mm bored throttle body's fs - pm
skyway0018746 is offline
post #17 of 18 Old 01-08-2015, 08:24 PM
muddflow
I have a CSF three row (copper/brass) purchased several years ago. No problems. On road temperatures stay between 195 - 205. Sometimes the CTS stays at around 195, under 200.
In heavy sand, using the oe aux fan keeps coolant temperatures at around ~210 and less.
You're right about some of the more expensive radiators may not hold up under some type of conditions.
There was one person I remember from several years ago with a ~$500.00 all aluminum. Blew it out by cracking the welds.
muddflow is offline
post #18 of 18 Old 01-09-2015, 11:22 AM
AZ Jeff
2014 JK Wrangler
My personal experience with AFTERMARKET (not Mopar brand) radiators is that the CSF soldered brass ones are the best out there. They beat out any of the other OEM-type aluminum/crimped plastic ones, and can be had at a decent price.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
cooling system , radiator
