What axles came stock in a 99 XJ 4.0? Other axle related questions too.. - JeepForum.com
post #1 of 10 Old 05-24-2009, 09:43 PM Thread Starter
Mike94ZLT1
Auto trans, if it matters. I've decided to modify this thing, I want to lift it and put larger tires on it and blah blah blah. While I am doing that, I wanted to beef up the axles to handle the strain of larger tires and off road abuse. I have no interest whatsoever in rock crawling, flexing, or any of that. I want to play in the mud! Anyways, what gear ratio should I go with if I am going to put 31" tires on? How do I correct my speedometer for the change in tire size and gear ratio? Thanks guys!
2009 Jeep Grand Cherokee Laredo 4.7, 4WD, Stock for now
2006 Ford E-150 4.6, RWD, "The Happy Bus"
1999 Corvette FRC 383 LS6 stroker, built drivetrain, full suspension, not much left that's stock
1937 Ford 5 Window Coupe 327 SBC, M-22 4 speed, etc..
Mike94ZLT1 is offline
post #2 of 10 Old 05-24-2009, 09:52 PM
Jon00XJ
the 99 should have came with a D30 front axle and 8.25 rear.
the gears should be 353 unles you have the towing package then i believe it was 373
for 31's i would probably go with 4.10's or 4.11's you wont need anything too low actually your factory gears maybe ok as far as your speedo use google there are a couple different products out there that fix that for ya i think www.quadratec.com has a few on their site you can check out.
hope this helps
Jon00XJ is offline
post #3 of 10 Old 05-24-2009, 10:10 PM
xjay1999
Dana35
99' XJ 2DR,Chopped+Caged,.98 XJ 2Dr. 07' JK 2 DR. Rubicon. 2011 Grand Cherokee Ltd.
xjay1999 is offline
post #4 of 10 Old 05-24-2009, 10:26 PM
Jon00XJ
Just found out i maybe wrong about the 8.25 it was my understanding that 96 was a crossover year and 97= had the 8.25 easy way to find out is to go look at your diff cover it will tell you what you got
Jon00XJ is offline
post #5 of 10 Old 05-25-2009, 01:41 AM Thread Starter
Mike94ZLT1
What am I looking for under there?
post #6 of 10 Old 05-25-2009, 01:49 AM
findel91
I'm nearly sure you have d30 and c8.25's.. a good way to tell is if your rear diff has a square bottom.. its a c8.25
-findel91
practice safe lunch use condiments
findel91 is offline
post #7 of 10 Old 05-25-2009, 07:25 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The dana 35 was used in every year of XJ, anything from 91-up can have either the dana 35, or the chrysler 8.25. From 96-down the chrysler 8.25 will be 27 splined axles, from 96.5-up they are 29 splined axles. The 96's will be hit or miss on the spline count and the only way to verify is to pull an axle and count. The gear ratio's for your model will be 3:55 to 1 for the automatics, and 3:07 to1 for the manual. 4:10 to 1 for a 4cyl. model. Using axles from the 4cyl. would be the best option for going to 4:10 gears which are perfect for 31" tires, and you can change the speedo gear to correct the speedometer.http://jeepin.com/features/speedogear/index.asp
xjfever is offline
post #8 of 10 Old 05-25-2009, 10:56 AM
Jon00XJ
it should be stamped on the diff cover may have to clean a little road grim off to see it
Jon00XJ is offline
post #9 of 10 Old 05-25-2009, 01:24 PM Thread Starter
Mike94ZLT1
Front and rear?
post #10 of 10 Old 05-25-2009, 01:43 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
All Cherokees sold in North America have a Dana 30 front axle. The rear axle needs to be identified by its shape. Stamping and factory axle tags are usually unreadable or long gone.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
00XJ Oil Pressure Related Questions theducksguts XJ Cherokee Technical Forum 15 11-21-2009 06:25 AM
A couple questions (gears and exhaust related). Dannyboy18 XJ Cherokee Technical Forum 5 03-23-2007 11:01 AM
stock axles vs alloy axles ? NOS/86 XJ Cherokee Technical Forum 7 02-21-2006 09:22 AM
A few quick XJ questions (oil and tint related) Dannyboy18 XJ Cherokee Technical Forum 1 02-06-2005 03:27 PM
stereo related questions BrokeMyJeep XJ Cherokee Technical Forum 1 10-07-2004 12:42 PM
