Weird leaking from diff relief valve - JeepForum.com
post #1 of 7 Old 04-08-2014, 02:41 PM Thread Starter
xjjames1
I recently replaced my diff cover on my front axle its a dana 30 with the solid axle cover and sealed it up and filled it to the hole but for some reason its leaking out of the tube that goes up into the engine bay then leaking down and all over everything. Does anyone have suggestions ? Im stumped on this one.
xjjames1 is offline
post #2 of 7 Old 04-08-2014, 03:09 PM
93gc40
Is diff overfilled?
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline
post #3 of 7 Old 04-08-2014, 03:11 PM
biffgnar
biffgnar's Avatar
Fill hole in the Solid cover may have been higher than stock so you mistakenly overfilled. It is self correcting.
biffgnar is offline
post #4 of 7 Old 04-08-2014, 04:08 PM Thread Starter
xjjames1
Being self correcting makes cense but its still coming out of the tube and I replaced the diff cover and filled it 4 months back so I might try to just clamp off the top of that hose. Not sure if that will hurt it at all.
xjjames1 is offline
post #5 of 7 Old 04-08-2014, 06:25 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by xjjames1 View Post
... might try to just clamp off the top of that hose. Not sure if that will hurt it at all.
What for ? When the diff is happy with the fluid level, it will stop spewing fluid. Other than some gear oil here and there, no harm done.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
“The powers delegated by the proposed Constitution to the federal government are few and defined. Those which are to remain
in the State governments are numerous and indefinite.”
- James Madison
CJ7-Tim is offline
post #6 of 7 Old 04-09-2014, 06:50 AM
xjfever
xjfever's Avatar
1995 XJ Cherokee
Do not clamp off the breather tube, doing so will result in a blown seal since that pressure has to go somewhere. I would pull the cover/drain fluid, then put the cover back on and fill with the correct amount of fluid.
xjfever is offline
post #7 of 7 Old 04-10-2014, 01:24 PM Thread Starter
xjjames1
ok that sounds like the best thing to do thanks for the advice.
xjjames1 is offline
dana 30 , differential
