Vacuum line to heater valve - JeepForum.com
 1Likes
  • 1 Post By sAe23
post #1 of 8 Old 12-06-2019, 02:56 PM Thread Starter
sAe23
1995 XJ Cherokee
Hello,
I have had my heater core bypassed for a while now.
The other day I noticed that a vacuum line attached to the diverter valve was broken.
I can't find where it attaches to (or any other part of the line).
I checked my copy of the FSM but didn't find any reference to this line.
Does anyone know where or what it connects to?
TIA
Steve
sAe23 is offline
post #2 of 8 Old 12-06-2019, 08:25 PM Thread Starter
sAe23
1995 XJ Cherokee
So I looked through the FSM again and found this diagram...
Does anyone know where that "manifold" is?
TIA
sAe23 is offline
post #3 of 8 Old 12-08-2019, 09:32 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
This help?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 8 Old 12-09-2019, 06:27 PM
KF4SQB
1994 XJ Cherokee
I believe that is referring to the vacuum hose harness that plugs onto the back of the HVAC control panel in the dash. That is, ultimately, where the vacuum hose to the heater valve goes to.
4-wheeling: because football, basketball, baseball, and golf only require one ball!
Confidence: The feeling you get just before you fully understand the situation!
KF4SQB is offline
post #5 of 8 Old 12-10-2019, 12:24 AM Thread Starter
sAe23
1995 XJ Cherokee
Cruizer54
In my setup, the connector marked "To Heater-A/C controls" has something connected to it that goes off towards the passenger side inner fender.
When I get a chance, I will dig through all the bundled wires and stuff and see if I can find another connection.
Thanks for the help.
sAe23 is offline
post #6 of 8 Old 12-10-2019, 12:29 AM Thread Starter
sAe23
1995 XJ Cherokee
So, the vacuum lines go in to the passenger cabin, then back out to the engine compartment?
And it's behind the HVAC panel?
Yeah, I'm not gonna mess with it LOL
The other end of the broken line is probably hidden beneath the wire loom (and other stuff).
Thanks
sAe23 is offline
post #7 of 8 Old 12-10-2019, 06:34 PM
KF4SQB
1994 XJ Cherokee
Yes, thats correct. There is a vacuum supply line that goes through the firewall and under the dash, and connects to the back of the HVAC control. The control has a vacuum "switch" that routes vacuum to control the doors in the ducting that determine where the air comes out, and select fresh or recirculated air. There is also a line that goes back under the hood to control the valve for the heater core. The HVAC control is not hard to remove.
KF4SQB is offline
post #8 of 8 Old 12-14-2019, 10:44 PM Thread Starter
sAe23
1995 XJ Cherokee
So I found the other half of the broken hose... It was hiding under the bundled wires next to a piece of the vacuum hose that WAS visible...
Went to untangle it so I could DO something to plug it, and another piece broke off :/
I was able to melt the tip of the remaining hose and squish it shut with pliers...
Hopefully I stopped any leaks
cruiser54 likes this.
sAe23 is offline
