Upper Door Hinge Re-Weld - JeepForum.com
 5Likes
  • 1 Post By Luuca
  • 2 Post By chris87xj
  • 1 Post By hofojr
  • 1 Post By xjpete
post #1 of 12 Old 12-16-2018, 02:13 PM Thread Starter
Luuca
Typical /f12 Hooligan
Luuca's Avatar
1986 MJ Comanche
My son drives a 1995 XJ Sport. Completely stock specimen in excellent condition. He came in the other day and simply said, "My door is falling off."
To my amazement, this is what I saw when I opened the drivers side door and it nearly fell off in my hand.
All the welds for the unibody side of the hinge had broken off and the door sagged and was nearly impossible to close. After some research, I figured that with the help of a friend that welds from work, we'd tackle this issue.
First we stripped off the fender skin. You will have to take off the front grill, the fender liner, and related items. Once you get to this point, you can start prepping for welding.
I cleaned up the paint around the old welds with a wire wheel until we had no paint n the edge of the hinge and the body panel. Then my buddy sat me inside the jeep with a fire extinguisher watching for smoke or odd smell inside while he re-welded the hinge onto the body. It's not going to win any prizes, but it's a solid weld and the door works great again.
let it cool off, ome self etching primer and some white enamel paint to cover the bare metal, slap it all back together and aside from some greasy fingerprints, good as it was before.
In total, with cooling off and watching for any let fires in the cab, took about 3 hours from start to finish.
downs likes this.
91 YJ "Alice"
YJOTM Sept. 2017
05 LJ Rubicon "Ghost" SOLD
Luck Favours The Prepared
Luuca is offline
post #2 of 12 Old 12-16-2018, 10:21 PM
chris87xj
RIP Chris87xj
chris87xj's Avatar
1987 XJ Cherokee
Good write up here thanks.
This is actually a not uncommon XJ ailment particularly on 2-dr models due to the larger heavier doors so I've added a link to this in the Useful write-ups by forum members thread. Your effort turned out a lot cleaner than many I've seen because not everyone goes to the effort of removing the fender skin.
Luuca and downs like this.
***Chris***
chris87xj is offline
post #3 of 12 Old 12-17-2018, 12:05 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Nice job!
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #4 of 12 Old 02-19-2020, 08:05 PM
hofojr
hofojr's Avatar
Upper hinge Weld
Ive got the same thing happening on my 95 two door XJ. Door starting to sag and hard to close without lifting it to align the latch. I live in South Florida, any recomendations?
hofojr is offline
post #5 of 12 Old 02-21-2020, 10:02 AM
PhilipJ
PhilipJ's Avatar
https://www.hooliganoffroad.com/coll...-hinge-support
PhilipJ is offline
post #6 of 12 Old 02-22-2020, 05:03 AM
chris87xj
RIP Chris87xj
chris87xj's Avatar
1987 XJ Cherokee
That's sweet!
***Chris***
post #7 of 12 Old 02-22-2020, 08:30 PM
soapy
soapy's Avatar
My 2001 had the same door issue. I had a body shop install 2 new hinges when they fixed mine.
soapy is offline
post #8 of 12 Old 02-23-2020, 01:35 AM
chris87xj
RIP Chris87xj
chris87xj's Avatar
1987 XJ Cherokee
Originally Posted by soapy View Post
My 2001 had the same door issue. I had a body install 2 new hinges when they fixed mine.
I'm curious how much a body shop would charge to replace a hinge and repair the door.
***Chris***
post #9 of 12 Old 02-23-2020, 04:30 PM
soapy
soapy's Avatar
As I recall it was around $300.
soapy is offline
post #10 of 12 Old 06-22-2020, 05:36 PM
hofojr
hofojr's Avatar
XJ hinge
My body shop charged me $275. Rewelded hinge and now door closes like new.
downs likes this.
Keep On Jeepin On
hofojr is offline
post #11 of 12 Old 06-23-2020, 08:27 AM
xjpete
xjpete's Avatar
1997 XJ Cherokee
The weld looks pretty good considering you are welding a thick metal onto a thin surface.
Luuca likes this.
2001 Jeep Grand Cherokee WJ Laredo 4.0 purchased Sept 2014.
xjpete is offline
post #12 of 12 Old 06-13-2021, 12:41 AM
DHVargas
I've got the same issue on my 96 XJ on the drivers side.
DHVargas is offline
