Unicorn non clip Dana 35. . need wheel bearing and seal - JeepForum.com
post #1 of 5 Old 08-04-2019, 07:34 PM Thread Starter
noise_maker
noise_maker's Avatar
My kid blew the rear end in his xj by letting the fluid run out. It's stock height and I wouldn't trust him with lifting it yet. My plan was to save some money (reusing his drive shaft , breaks if needed etc) so I specifically went looking for a Dana 35.
I had some trouble but I finally found one and and jy said it was from a 96 well I think they lied to me or maybe it was swapped in what they pulled it from. Regardless I'm guessing form like a 89 or older but I have no idea
It's a non c clip Dana 35 and had a leaking axle seal. The inside looked ok and didn't notice at the time it was a non c-clip.
It need an axle seal, bearing, retainer, break shoes and I'm betting wheel cylinders. Everyplace I called only has c clip parts regardless of how old I tell them the axle is.
Anyone know for sure when non clip Dana 35s were available or even better part numbers for the stuff I need to make this work.
I
noise_maker is offline
post #2 of 5 Old 08-05-2019, 11:01 AM
RLE
RLE's Avatar
From the forum's sticky "Cherokee stock specs":
Dana 35 non c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 84-89
Dana 35 c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 90-01
Try looking for 89 parts on rockauto.com and see what you get.
RLE is offline
post #3 of 5 Old 08-05-2019, 01:40 PM
Saudade
1988 XJ Cherokee
Look on the axle tube and you should find some numbers. The pic below show the "Bill of materials" (BOM) for my 88. Note that mine is 605389-6. The space becomes a hyphen "-". Then enter this BOM into the field on this Dana Website.
https://www.expert.dana.com/expertforms/deabill.aspx (note, the site is very slow to respond)
Then click on the search result for additional details
Saudade is offline
post #4 of 5 Old 08-05-2019, 01:46 PM Thread Starter
noise_maker
Attachment 3848389
This is great! thanks
post #5 of 5 Old 08-14-2019, 09:03 AM Thread Starter
noise_maker
For others in need...my 84-98 axle was not stamped as above but I was able to sort it out
Inner seal national 473214
Bearing /retainer national a-9
Outer seal national 2146
The breaks are 10" but the hardware is a different story and I ended up with allot of different stuff to find reasonable replacements
