Turn Signal Flasher Bad? - JeepForum.com
post #1 of 4 Old 10-19-2011, 02:53 PM Thread Starter
DieselDreamer
Hello forum!
It has been awhile since I posted. Seems the search is an awesome function in where I don't need to post unless I have to. However on this subject, I'm not for sure on the problem even when the search function was used.
I recently have been having this problem in where my turn signal while on dies out if after it flashes three times, then on the fourth time it dimes out and doesn't flash at all. I have to pop it back into left or right (doesn't on both directions) and it starts this all over again. When my vehicle is still cold the problem is worse then when warm. When warm, the problem occurs less frequently but still occurs nonetheless.
If anyone could help me out as to what it might be please let me know.
Erik
1999 Jeep Cherokee - Stock
DieselDreamer is offline
post #2 of 4 Old 10-19-2011, 03:08 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Go to the auto parts store and buy a new flasher unit and install it. It is located behind the dash below the headlight switch.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #3 of 4 Old 10-19-2011, 03:15 PM Thread Starter
DieselDreamer
Your the best Tim! Your writeup for 99's regarding brakes & wheel bearings was great for my wheel bearing purchases!
post #4 of 4 Old 10-20-2011, 11:21 AM
wwjeeper
just had this problem with mine, flasher was the problem just like tim said. at autozone it was 15.99, turn signal flasher EP27
wwjeeper is offline
Where the **** is the turn signal flasher?! Swagger_Wagon XJ Cherokee Technical Forum 16 01-02-2011 12:23 AM
turn signal/ hazard flasher location? 77f2504by4 XJ Cherokee Technical Forum 4 09-21-2010 11:18 AM
turn signal flasher GatorFanJosh XJ Cherokee Technical Forum 3 05-05-2010 05:27 PM
Emergency Flasher comes on instead of left turn signal ddunaway XJ Cherokee Technical Forum 14 06-03-2007 11:02 AM
Turn signal flasher juan0548 XJ Cherokee Technical Forum 3 07-24-2005 12:09 AM
