Trying to replace this screw / fastern clip - JeepForum.com
 1Likes
  • 1 Post By 2oldjeeps
post #1 of 13 Old 08-03-2020, 12:24 PM Thread Starter
bradleyheathhays
bradleyheathhays's Avatar
Trying to replace this screw / fastener clip
96 XJ. One of my top 2 e-fan support screws is missing from where it mounts on that top cross support. There's a small black C shaped piece of metal that's stamped to accept the screw. C piece goes onto the edge of the cross support and then the screw goes through the hole.
Anyone know how I can identify this part number where I can order it, of what this piece is called so I can just look for a universal one? I know I could just shove a screw through it but I'd rather get the right piece.
~~_/) ~~
bradleyheathhays is offline
post #2 of 13 Old 08-03-2020, 04:28 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Oddly enough, that it is called a nut-clip, and your local hardware store should have about a dozen different sizes to choose from.
Whatever similar size hardware store screw fits will be fine.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 13 Old 08-03-2020, 10:19 PM
clsc7777
Go to your local O'reilly and ask for the Doorman catalog and match up the part; it takes a lot of page flipping or go to your local pick and pull. Sometimes fasteners like that are hard to find. That or use a stout zip-tie as I have done in the past.
clsc7777 is offline
post #4 of 13 Old 08-04-2020, 01:44 AM
UKXJ
On reflection . . .
OP seems to be describing the part he hasn't got - or is just the screw he's missing?
Don't assume both sides of the shroud are secured the same way, the inboard fitting on my '98 is the fir tree part of the the harness/overflow pipe clip.
The clip OP describes is the cheap nasty one for self-tappers, whereas the shroud's held on by M5(?) machine screws, the better clips actually incorporate a nut; I'd get a pack of those from a hardware store & change them all while I was at it.
Thinking about it, there's actually 3 types, the ones with an integral caged nut I was referring to are probably overkill &, in any event, hard to find & needlessly expensive.
The 3rd type have a threaded turret (instead of a single spiral for a self-tapper) which is actually the OE type (just been out to check my spare slam panel) - should be able to pick up a pack of, maybe, 1/2-doz for $1 or so at any auto parts store.
UKXJ is offline
post #5 of 13 Old 08-07-2020, 05:19 PM Thread Starter
bradleyheathhays
Yes, the ones I have are the the threaded turret kind. The socket that fits it is an 8mm so does that mean it's an M8?
~~_/) ~~
post #6 of 13 Old 08-07-2020, 06:16 PM
2oldjeeps
need a good junk box,,or room,,,or barn...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #7 of 13 Old 08-10-2020, 02:13 PM
UKXJ
No, the figure after the "M" is the diameter of the bolt, in mm's.
So an M8 nut or bolt would normally have a 13mm head.
What we call 8mm bolts are M5, although (just to confuse) M5's can have 7mm heads.
Sorry I didn't answer sooner, but missed your question somewhere along the line.
UKXJ is offline
post #8 of 13 Old 08-11-2020, 10:25 AM Thread Starter
bradleyheathhays
All good thanks for the info. Probably should have learned this long time ago.
~~_/) ~~
post #9 of 13 Old 08-11-2020, 01:18 PM
2oldjeeps
working with metric. dump out a box of tools. then get another box of tools. dump them out.
then see if you have the right one.
go to the tool store for more tools. repeat above...
JWELK likes this.
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #10 of 13 Old 08-11-2020, 01:58 PM
Boojo35
1987 YJ Wrangler
Somebody already called it a clip nut. That is an accurate name. The do come in m6x1.0 which I believe is what you probably have. Not all of them are for self tappers. Parts stores or a really comprehensive hardware should have them.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #11 of 13 Old 08-11-2020, 03:26 PM
UKXJ
Sorry if I confused the issue referring to self tappers (that type of "spire nut" is more common here) because I thought that's what OP was describing - 'til I checked my own.
Not sure, from memory, that they are M6 though, & M6 bolts generally have 10mm heads, which I why I thought they were M5's, as they have 8mm heads BUT Jeep do seem to have a thing about bolts with non-standard size heads (&, indeed, some nuts that are oversize across the flats.)
UKXJ is offline
post #12 of 13 Old 08-12-2020, 08:30 PM Thread Starter
bradleyheathhays
I initially described the metal piece as stamped and that wasn't accurate. Didn't find out it had all those threads to accept the screw until I took it out after my initial post. Sorry bout the confusion. Found a good set on Amazon that should be here Friday so all four of the top fasteners are getting replaced. 2 for the e-fan and 2 for the regular fan shroud.
~~_/) ~~
post #13 of 13 Old 08-12-2020, 08:57 PM
2oldjeeps
in a pinch a couple years ago i used a twisted wire. still good..
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
